Author Topic: help figure out what needle I have  (Read 4648 times)
Offline dirtyd
« on: September 21, 2014, 10:31:10 PM »
I have a Keihin 38mm A/S quadvent and I want to try out some leaner needles but I don't know what I have to start with. I looked at the stuff posted in the "jetting data base" thread to figure out the 3 letter conversion. But the numbers on my needle are not like whats on the pages. Here is what is marked on my needle (A715 289R A327 A487)
87 Tecate4- new project
« Reply #1 on: September 22, 2014, 07:44:53 PM »
Those numbers are not numbers you will find on the Keihin after market needles.  I think you have a needle that is an OEM number.  I do not have a way of cross-referencing the numbers with the needles whose dimensions are published.
In a situation like this I would carefully measure the needled and then compare the dimensions to those that are published so that you have a reference point to work from
Offline dirtyd
« Reply #2 on: September 22, 2014, 09:00:57 PM »
thanks Jerry. I googled that number and got some threads from other forums and it looks to be OEM 2000 CR250 needle
Offline RyanWsly
« Reply #3 on: September 24, 2014, 06:20:37 PM »
Just for reference I have a DGJ in mine. I ran that needle with a stock cylinder and my 300 cylinder so it should be a fairly safe starting needle for you, I'm in IN so weather ect. should be similar. From what I read that is some weird triple taper needle from a CR250 so I'm guessing that is why it has all of those funny numbers.
