Author Topic: removing rear sprocket holder  (Read 11334 times)
Offline marine
« on: October 02, 2014, 02:59:19 AM »
Hi guys how in the hell do you remove the rear sprocket holder off an axle? And if I manage to get it off and put it back together ho do i know if its lined up with the front sprocket? Thanks guys in advance for your help!..USMC
« Reply #1 on: October 02, 2014, 01:00:40 PM »
They are press fit. They only way I have removed them, was with a hydraulic press. Push it a little towards the center of the axle, remove the ring-clip. Then press it off the opposite direction. Install in reverse.
With the hub set tight on the ring-clip, chain alignment should be good.
No soldier, left behind!!!!! Free Andrew Tahmooressi USMC !!!!!
Offline marine
« Reply #2 on: October 02, 2014, 01:16:51 PM »
Quote from: F-Red;43724
Thanks Red for the info...WE LEAVE NO ONE BEHIND THIS MARINE WILL BE COMING HOME SOON ONE WAY OR ANOTHER!!!...SEMPER FI..!!!
« Reply #3 on: October 02, 2014, 01:30:00 PM »
Quote from: marine;43698
how do i know if its lined up with the front sprocket? Thanks guys in advance for your help!..USMC
Like F-Red said........the circlip on the sprocket hub will set the alignment of the sprocket. Then when you snug up the big axle nut, everything will be aligned
