Author Topic: transmission problem  (Read 3659 times)
Offline aberegg05
« on: October 02, 2014, 08:47:45 PM »
While I'm cruisin in 4th gear and I let off the throttle and coast a little and then get back on it the trans seems like its trying to "catch" back up and slams a little. It doesnt slip at all either. Whats causing this?
« Reply #1 on: October 02, 2014, 09:52:34 PM »
The transmission is direct drive. No slipping can happen cause there is nothing to slip. Any problems you may have are going to be in the clutch.
Offline aberegg05
« Reply #2 on: October 02, 2014, 10:10:58 PM »
Only happens when in forth gear. Broken tooth?
« Reply #3 on: October 02, 2014, 11:03:44 PM »
Quote from: aberegg05;43769
I see what your saying. Does not work quite right until that broken piece gets back where it needs to be.
« Last Edit: October 03, 2014, 12:52:13 AM by Pumashine »
