Author Topic: 02-07 cr top end  (Read 5129 times)
02-07 cr top end
« on: October 12, 2014, 01:48:48 AM »
I have a friend asking if would be possible to run a 02-07 cr top end with ignition.
02-07 cr top end
« Reply #1 on: October 12, 2014, 05:01:00 AM »
??? 02-07 are case reed inducted.
Best regards
-Jason
02-07 cr top end
« Reply #2 on: October 12, 2014, 11:25:19 AM »
I do not know anything about the cr stuff. That's why I'm asking here. He was curious about it. Because of the electric pv. He wants to put cr ignition on his r and thought he if it was possible. He could make his a pv'd motor that way.
02-07 cr top end
« Reply #3 on: October 12, 2014, 01:15:18 PM »
No he cant use it on the trx/atc 250r bottom end.
02-07 cr top end
« Reply #4 on: October 12, 2014, 01:57:05 PM »
see that now thanks for the replies.
Offline KsSandduner
02-07 cr top end
« Reply #5 on: October 13, 2014, 12:12:09 PM »
FTZ does work with the CR cylinders on TRX bottom ends. I have the '91 style CR cylinder on my TRX bottom end which is a bolt on. On their website they show they also do the newer CR cylinders, but they require welding and modifications to the TRX cases. I have no idea what years of cylinders they consider "newer".
Offline dariusld
02-07 cr top end
« Reply #6 on: November 08, 2014, 10:54:02 PM »
Quote from: KsSandduner;44471
From the picture on their site, it looks to be pre 2002.
02-07 cr top end
« Reply #7 on: November 09, 2014, 12:29:06 AM »
Those years of CR cylinders are the case reed design so they won't work.
But the idea of using the electric power valve is a good one. It would cure the issues the 250R cylinders have with the pressure operated PV's
