Author Topic: Two bottom ends-88 and a 89  (Read 3831 times)
« on: October 17, 2014, 09:44:00 PM »
I have a 88 and a 89 bottem end I am looking to sell. Basically I value the cases as junk unless someone would want to pay and have them fixed. The black 88 one has had welding done to it,drain plug is not original and is missing the clutch cover. The red 89 has cracked left case,stator cover and is missing the clutch cover also. You are basically buying these for the internals. The black 88 also has a Hot Rods rod on it. Both baskets look excellent with no grooves. $375 each or $700 for the pair shipped to cont. 48 only.  SOLD
« Last Edit: November 08, 2014, 06:15:18 PM by red88r »
Offline Tyler 54
« Reply #1 on: October 17, 2014, 09:48:58 PM »
Were are cases damaged exactly?
« Reply #2 on: October 17, 2014, 10:08:03 PM »
Black one has had welding done behind sprocket area and the case saver mounts are cobbled up.  The black one also leaks oil from parts of the center case gasket.  The red one has cracks back where the rear motor mount bolt goes thru.  It is the grey jb weld? you see in the pic.
Offline Tyler 54
« Reply #3 on: October 17, 2014, 10:17:47 PM »
Close up of the crack on the 89 engine? You have any cylinders?
« Reply #4 on: October 17, 2014, 11:20:09 PM »
I have two 88 jugs and a 86 but I don't know if I want to sell them.  Was going to have my uncle port the one.  He has done amazing work on vintage sleds,400ex's,450r's and a couple of Harley's.
« Reply #5 on: October 30, 2014, 11:28:56 PM »
Sold
« Last Edit: November 08, 2014, 06:15:44 PM by red88r »
