Author Topic: TRX250r exhaust  (Read 11647 times)
Offline stevo936
TRX250r exhaust
« on: October 30, 2014, 01:42:26 PM »
Hey guys im new to the forum and 2-strokes in general.  I have an 05 trx450r but I recently just purchased a 1988 trx250r.  It needs all new exhaust from the the head back.
First question is what is a good low to mid range pipe that is not deafing?  The guy i bought it off looked like it was off a dirtbike and all hacked together.
Also the guy I bought if off said it might have an 86 motor in it but he wasn't sure.  Is there a way to find out this out with a tag somewhere and do they pipes differ from 86-89?
Also I removed the carb and took it apart.  It has a 150 main and 45 pilot? Does that seem about right for the jetting.  It still had the stock airbox lid on the one hold drilled in it.  I plan on taking the lid off completely off if that would be the better thing to do?
Thanks
« Last Edit: October 30, 2014, 01:56:41 PM by stevo936 »
TRX250r exhaust
« Reply #1 on: October 30, 2014, 01:54:33 PM »
Pipes are all the same for the 86-89. The motors can be identified through visual examination. But it is easiest with a picture of the front where the exhaust flange is.
If you are just looking to replace stock exhaust then a simple FMF exhaust system will work fine. You will need to check for the 3 stock exhaust hangers though. http://www.ebay.com/itm/HONDA-TRX250R-TRX-250R-FMF-FATTY-EXHAUST-PIPE-SILENCER-87-89-/151412064349?pt=Motors_ATV_Parts_Accessories&hash=item2340dcc05d&vxp=mtr
Offline PORTED R
TRX250r exhaust
« Reply #2 on: October 30, 2014, 01:59:31 PM »
Best way too tell if u got 86 or 88 cases
Is by looking at the front motor mount area on the motor
If u look there the cases are cut back in that area exposing the bolt that goes threw
Post a pic if u can
Some pipe companies offer a 86 version and 88/89 version
But the big names like ESR,LED,Paul Turner they are the same
McCoy ProX 350 5mil Duner
TRX250r exhaust
« Reply #3 on: October 30, 2014, 02:11:04 PM »
Offline PORTED R
TRX250r exhaust
« Reply #4 on: October 30, 2014, 03:02:40 PM »
^^^^yup the trx5 is pretty much the standard in all around performance for the Honda
And It's a ESR product
Offline stevo936
TRX250r exhaust
« Reply #5 on: October 30, 2014, 04:33:22 PM »
This hole freaked me out when i first seen it..lol but i read that its factory.  Ill try to get some more later
Offline stevo936
TRX250r exhaust
« Reply #6 on: October 30, 2014, 05:57:34 PM »
Here are a few more
Offline PORTED R
TRX250r exhaust
« Reply #7 on: October 30, 2014, 06:55:52 PM »
Looks like a basic 86 motor
But with that spacer plate there means u got a 88 style crank with a 86 piston setup
The frame 88 style
Offline stevo936
TRX250r exhaust
« Reply #8 on: October 30, 2014, 07:04:11 PM »
Im sorry but I'm not really sure what ur meaning by the spacer plate?
Offline PORTED R
TRX250r exhaust
« Reply #9 on: October 30, 2014, 07:28:08 PM »
If you notice,theres a gasket ,aluminum plate then gasket
Between the bottom end and cylinder
Offline PORTED R
TRX250r exhaust
« Reply #10 on: October 30, 2014, 07:28:55 PM »
Stock would have one gasket and no plate
TRX250r exhaust
« Reply #11 on: October 30, 2014, 07:41:35 PM »
Quote from: stevo936;45288
Welcome to the site and don't be worried about the mumbo jumbo we speak. There were different cylinders and crankshafts for different years. It only means something if you are ordering replacement motor parts. It does appear to be an 86 motor but as far as pipes are concerned all years fit the same.
Offline Transmatic
TRX250r exhaust
« Reply #12 on: October 30, 2014, 08:25:58 PM »
Welcome to the site. Lots of great info and knowledgeable people. I've spent hours reading old threads about this and that and have gained a lot of knowledge. I too came from the 4 stroke world and had lots of questions. I also have a similar setup, 88 frame with spacer plate to accommodate the 86 piston. Do some reading on the short rod vs long rod motors and that may clear up some questions you have. If not, ask away.
Offline stevo936
TRX250r exhaust
« Reply #13 on: October 30, 2014, 08:34:17 PM »
Ok thx guys I see what your saying now with the plate.  As far as the jetting is concerned, does that seem about normal.  The quad actually ran very well even with hacked up exhaust that was on it but it did not idle.
Offline stevo936
TRX250r exhaust
« Reply #14 on: October 30, 2014, 08:45:25 PM »
Thx transmatic i will do that:)  I read up a little and it seemed the 88 style was the better of the two with the motor.  Sux it's an 86 but it still runs good.
I've loved these quads since i was a kid watching old school huevos movies haha.  Im sure I will have many more questions thx!!!
