Author Topic: Green horn builder  (Read 6686 times)
Offline tlr7272
Green horn builder
« on: November 21, 2014, 10:37:41 AM »
Im strating on my first real total build , i pikd up an 86 which was actually worse off then i thjought.. I traded my gsxr1000 for it cuz im yired of cops on the steets... But bak to quad i completly tore it apart down to frame the motor actayully ran really well so im thinking about justkeeping motor as is just adding electronics , like dyna cdi box, ignitiuon advancer, v-force reeds  and thats where the problem im havin is ii want to use the the v force 3 with torque spacer is there a difference in v-forces 3s  i was gonna buy one off eay and guy said i couldnt use spacer with it ???? So idk im just trying to build the best woods quad i can with 5,000$ budget ..... Anyone have any ideas ???? Cuz i need them i  havew riden and raced eeverthing my whoile life but it was always built for me...... Thanks greenhorn
Green horn builder
« Reply #1 on: November 21, 2014, 10:47:55 AM »
A spacer won't change much. It really comes down to how much space you end up with down there. If you go to big bore then the spacers start to get in the way. Most go with a bigger carb 38mm-39mm. When you go to the bigger carb you then have to watch out for the inlet and outlet size of carb to intake manifold. Figure out what you want /need before buying.
Green horn builder
« Reply #2 on: November 21, 2014, 10:58:15 AM »
welcome. if you are going to stick to stock ign, just use the stock cdi, dont waste money on a aftermarket cdi box. if you want to upgrade the electronics, pick up a 02-07 cr250 ign system. the best ignitions are the 01 cr ignitions but they dont make the parts anymore for them, so the prices are ridiculous, and the 02-07 work the same. however, the cr ignition has a lighter flywheel so your riding skill level will determine if you can deal that in the woods.
there is vforce3 reed blocks for the trx250r, it is model #v305b. if you want to go with those, just buy the correct one for the trx250r, dont worry about the 'torque' spacer, not needed at all, doesnt add 'torque' lol.
what pipe does ur bike have? what carb? if these are all stock, this is the first way to free up the detuned motors potential before digging inside. let us know what u have and we can go from there
« Last Edit: November 21, 2014, 11:11:52 AM by JesseA420 »
Offline tlr7272
Green horn builder
« Reply #3 on: November 21, 2014, 11:57:00 AM »
fatty pipe and silencer but was thinking trx7 and I want a dfferent carb just not sure what one??? I was just looking at the bolt on esr 330 kit for woods?? are they worth it ... im open to anything I have 2 years to bulild it due to lawsuit and disability bs... so that's kinda why I wanted the I got lots a time and money once a month to put straight into it ....I have been piking things up on ebay that's where I got dyna cdi it was only 9$ so no biggy I have 01 cr ignition in watch was thinking about it  but what all do I have to do to use that and are the benefits worth it
Green horn builder
« Reply #4 on: November 21, 2014, 12:00:32 PM »
Get a 350 kit but not the bolt-on. Get your cases machined to accept the 350cc cylinder sleeve. This is much more reliable
Get the TRX5B pipe for the bigger cylinder.
For woods riding, get a 38mm Air Stryker or PWK carb
Use a good working OEM ignition and flywheel for the woods.....or if you can get your hands on a flywheel wright for the CR ignition, then go that route.
Offline tlr7272
Green horn builder
« Reply #5 on: November 21, 2014, 12:09:00 PM »
thank u   what do u think that will cost me and what brand 350???
Offline tlr7272
Green horn builder
« Reply #6 on: November 21, 2014, 12:09:52 PM »
but still get v-force 3 too??
Green horn builder
« Reply #7 on: November 21, 2014, 12:12:55 PM »
There are a lot of bolt on 330 out there. If you flat don't want to split your cases to have them bored for the larger sleeve the bolt on is a good way to make your ride a lot better for your use then work done to the oem cyl. If splitting your cases get the normal cyl and send your case 1/2's to esr and they will mod the case for free if you buy a cyl kit from them. That is the best way to go but there are a lot that don't want to split the cases and that is why there is a bolt on 330 kit.
Green horn builder
« Reply #8 on: November 21, 2014, 12:21:05 PM »
Quote from: tlr7272;46353
Get the ESR 350. You can look up all the prices on ESR's website. They will even bore your cases for free of you buy a certain engine kit
Quote from: tlr7272;46354
The VForce 3 will work on the 350cc ESR cylinder
Green horn builder
« Reply #9 on: November 21, 2014, 12:49:13 PM »
yes cr ignition is light years different and better than the 30 year old technology in the stock trx ignition, i dont have time to go into it now but im sure someone here can :)
in terms of cylinder work if you dont want to split cases (u must strip them to bare cases to have them bored for 330 cyl and bigger, and it is daunting for some people, especially if you have never done it before), just send ur stock jug to a trusted and reliable builder and have them port it accordingly, then pick up a trx5 pipe and a 38mm keihin carb with some vforce's. IMO i would go with an oem properly ported and setup top end, then a bolt on 310 which is actually only 295.
first thing i would do is put some feelers out to builders, tell them ur plans and see which you feel most comfortable with.
Offline tlr7272
Green horn builder
« Reply #10 on: November 22, 2014, 02:47:58 AM »
well please help me if any one could lay out an outline on everything I need to buildv a bad ass reliable quad I have 3 years im not even surev if I should use 86 frame im lost when it actually comesv down to a full buildvan I want everything that I need to do that I just traded my gsxr1000 for nthis and im pretty sure I got fd frame spars on bottom are cut out and a shitty plate welded in there mountsv are mangled........... I just cant b seen riding banything for 3 years lawsuit for back so basically I have quad tore down to frame in living room ............I need serious info HELP
'?????????????/ thanks
Offline tlr7272
Green horn builder
« Reply #11 on: November 22, 2014, 03:13:01 AM »
nice rocket jessea420 that's my love but I cant ride road or anything for 3 years I just traded my mint 2001 gsxr1000 for a 86 r????? I got screwed on thr deal ........ u win some u lose some some people don't know what honesty is!!!!!!!!!!!!!! anyway jessea420 watch for dumb asses cuz they everywhere!!!!!!!!!!!
Offline tlr7272
Green horn builder
« Reply #12 on: November 22, 2014, 03:25:34 AM »
if I split the caeses and go with 350 kit will it be reliable and good for xc/woods   ,,,  sand a few times a year  but for the most part itsd dirt and woods ??????????  how many horses can I get to rear wheels reliably.....???? will I have piped 450s up my ass??? the guys I ride with are set on yfz450s with full pipes and they tell me I m wasting my time and just get a 450..... so know its a mission to build a bad ass 250r
Offline tlr7272
Green horn builder
« Reply #13 on: November 22, 2014, 04:28:07 AM »
ok so im on ebay right now what do I buy 01 cr ignition coil staor flywheel ??? please tell me im lost but I wanna learn........thank u everyone this sight is great
Green horn builder
« Reply #14 on: November 22, 2014, 11:21:55 AM »
a 350 will run circles around a piped 450, but don't tell them that. contact esr to get the run down on every thing u need to do before sending him cases, or u can just take a road trip and pick this up and be done with it :)
http://omaha.craigslist.org/snw/4764797418.html
