Author Topic: lLOST BUILDER  (Read 2702 times)
Offline tlr7272
lLOST BUILDER
« on: November 23, 2014, 10:10:59 AM »
I am just starting a build, and I reLLY need some insight on cg ign and fklywheel?? if I am going to run this what is everything I need to make itwork??? as far as cdi, stator flywheel I have an 01 setup that im thinking about getting so could someone or anyone give some direction...... im planning on run ning a 330 -350 kit with it so if anyone knows that setup please let me know..... thank you
lLOST BUILDER
« Reply #1 on: November 23, 2014, 10:59:28 AM »
Go on eBay an look up item # 191414477180
That is a complete 2000 CR250 ignition. You will also need an adapter plate which can be purchased here:
These are the only parts you will need to. It is all bolt on.
