Author Topic: ESR 330 +4 stoker users, Are you Satisfied with this setup?  (Read 15424 times)
Offline The_Steve_Man
« Reply #15 on: December 03, 2014, 11:49:39 AM »
Keep us informed on how it runs. Can't wait to get one myself.
« Reply #16 on: December 03, 2014, 11:57:35 AM »
just saw on his facebook the chassis he used to mock up is gone to the customer now so he doesnt have anything to build one on anymore. i was talking with dave moore about his chassis and he said he makes pipes, never seen any of his work anywhere tho.
« Reply #17 on: December 03, 2014, 12:01:42 PM »
Here you a pipe!
Offline mrtwidster1
« Reply #18 on: December 03, 2014, 12:34:09 PM »
Quote from: The_Steve_Man;47016
Sure will.
Offline mrtwidster1
« Reply #19 on: December 09, 2014, 11:20:14 AM »
Cases, jug, crank and misc came in yesterday. Great turn around time by Eddie.
« Reply #20 on: December 09, 2014, 12:01:02 PM »
SWEET!!
Post pics of Christmas toys.... :)
Did you go natural or powder black or the new anodize black???
Offline mrtwidster1
« Reply #21 on: December 09, 2014, 12:30:38 PM »
« Reply #22 on: December 09, 2014, 12:39:43 PM »
Nice..
It even looks like Christmas..
Offline mrtwidster1
« Reply #23 on: December 09, 2014, 12:43:50 PM »
I bought a non engraved inspection cover that will replace the TRX logo. This motor is for my ATC hybrid build. I will also put a ESR Pump cover instead of the merrill on it due to the color difference. Will also buy a few other ESR "Goodies"
Eddie recommended the PV also. Just took his advice on what I needed. Just going to be a casual rider so no major porting.
Offline mrtwidster1
« Reply #24 on: December 09, 2014, 12:54:18 PM »
Haven't decided on the finish yet. leaning toward polishing because my original motor for this looks good.
Offline Bio86
« Reply #25 on: December 11, 2014, 11:32:58 AM »
How do the cases look?  Looks like the side case profile lines up pretty well against the cases.  I like the bolts!
McCoy\'d
Offline mrtwidster1
« Reply #26 on: December 11, 2014, 01:44:30 PM »
The cases look good in my opinion for being sand cast. The alignment with the clutch cover is good. I do not have any alignment dowels in place yet. I am going to take more detailed pics today or this weekend. If there are no assembly issues (and I have no reason to think otherwise) then i believe that the cases are a smokin deal at 599 with all the bearings and the seals. Mr Eddie uses the 8 ball CR crank bearings.
The sand casting is rough but can still be polished out. It will just take extra time. I am pretty sure I will be polishing
everything and adding some white highlight somewhere. I was going to have him leave the bearings and seals out for powder coating but his source fell through at that time. He went ahead and put them in, but in hindsight i should have told him not too. I will now have to protect everything from the dust that will be produced during the sanding and polishing process.
I will most likely buy the ignition cover from him also.
Offline mrtwidster1
« Reply #27 on: December 11, 2014, 03:14:39 PM »
Just want to add this note.. The website does not show the 330 pv stroker kit. I called him and he hooked me up (at a very good price I might add). He also has a limited supply of "blank no logo" clutch inspection plates.
He also gave me a red e brake block off plate and a jet wrench.
I also asked him about putting the powervalve "Plug" in if I wanted to do away with the PV. He said that I would loose bottom end but it could be plugged with no mechanical issues.
Offline 2k1lvr
« Reply #28 on: December 11, 2014, 03:35:32 PM »
I have the 330 pv stroker kit and I honestly cant tell any difference at all no matter where the pv is adjusted
89 trx5 pipe 38as carb esr330 pv cyl ported by BUBBA RAMSEY at BHP,+4 crank,cr ign,elka front shocks,lsr axle
Offline mrtwidster1
« Reply #29 on: December 12, 2014, 07:24:33 AM »
Quote from: 2k1lvr;47506
What porting did you go with? How do you like your setup?
