Author Topic: cr ignition?  (Read 10834 times)
Offline LAEGER525R
cr ignition?
« Reply #15 on: December 04, 2014, 03:34:19 PM »
If they are the same that will be great. I could have been told the wrong info years ago? I have always been interested in the 99 set up. I think the cdi is digital just 00-01. If your 99 flywheel ignition trigger is of by a few degrees you may be able rotate the stator plate & get it back within the timing needed to run the 01 cdi. Definitely update this thread with what you find out. This might be a good alternative for those that want build there own.
cr ignition?
« Reply #16 on: December 04, 2014, 05:46:08 PM »
I  will try to put a timing light to it in the next couple of days. Will definitely update on what I find.
cr ignition?
« Reply #17 on: December 05, 2014, 11:37:48 AM »
I'm just wondering, what is going to happen when that 99 anilog system trys to fire the 00~01 digital cdi box.
cr ignition?
« Reply #18 on: December 05, 2014, 12:24:59 PM »
my 99 stator components look just like the components on a 00-01 stator. Also by the manual should have the same test values when testing components. So far it has fired up twice no problem.
Offline bkm
cr ignition?
« Reply #19 on: December 15, 2014, 12:34:29 AM »
Any updates on this?
cr ignition?
« Reply #20 on: December 15, 2014, 11:22:37 PM »
not to much for updates. can't get it out off my garage right now. Other projects torn apart and in the way. It still fires up. Just don't like running to long right now. Fills garage with exhaust fumes and a little always gets in the house.
