Author Topic: Hard residue in exhaust  (Read 4297 times)
« on: December 02, 2014, 12:21:01 PM »
This is what I found in the header of my exhaust during my tear down for the winter. It doesn't look normal to me
Now I did suck in quite a bit of dirt and water on my trip to WV, due to my shitty air-box setup. How much I sucked in i'm not sure
Some pics of the piston
Offline C-Leigh Racing
« Reply #1 on: December 02, 2014, 03:51:16 PM »
Y'all see what the inside of that pipe looks like, now wonder where those scratches came from on the piston skirts & bore wall. Now just think, how confused that wave travel is as it travels back & forth through the pipe.
Race team for 2015
« Reply #2 on: December 02, 2014, 07:17:32 PM »
Quote from: C-Leigh Racing;46981
:thinking:
It is ugly inside there. Time for a SC Tbone07 and you won't have the extra sludge gumming up the pipe.
« Reply #3 on: December 02, 2014, 07:21:44 PM »
Quote from: Pumashine;46989
:thinking:
I know i'm running pretty rich, but i've run richer on bikes before and never had an exhaust that looked like this.
« Reply #4 on: December 02, 2014, 08:39:35 PM »
Take the pipe to an automotive rebuilder that has a hot tank.  Dirt can cause the inside of the pipe to look like that and so can castor two stroke oil when the engine is not being run real hard all of the time.  If you ran enough dirt through the engine to cause the pictured build up, your rod bearings, piston, and bore would probably already be history.
The top of your piston shows to have been running a little on the cool side.  The cool piston crown could be caused by being rich or just not holding the throttle wide open for more than a few gears at a time and then giving it 30 seconds of rest by idling around between full throttle blasts.
Offline udontknowme
« Reply #5 on: December 02, 2014, 09:02:37 PM »
given enough time your gonna see build up in the exh regardless what oil. might see more or less carbon depending what kind of oil, what ratio, how the bike was ridden and how the tune was.
« Reply #6 on: December 02, 2014, 09:54:13 PM »
Quote from: Jerry Hall;46993
This is exactly the type of riding I was doing on my last trip, virtually no wide open riding and tons of idling and putting around. I was also running castor 927 at a little richer than 32:1.
My piston and bore actually look pretty good. I'm throwing another piston and rings in it this winter for safe measure.
« Reply #7 on: December 02, 2014, 10:42:25 PM »
Wow, your pipe looks like my chimney before I swept it. Are you burning fir for fuel?:)
Offline StrokedAZ
« Reply #8 on: December 02, 2014, 11:36:21 PM »
^^^lol
86 TRX 250R
