Author Topic: Can a 89 kick starter be used in any year trx/atc?  (Read 2941 times)
Offline mrtwidster1
« on: December 03, 2014, 10:17:19 AM »
I am working on a new engine and I want to put a 89 kickstarter shaft and gear set in it. Is the only difference the bushing? Example 88/89 no bushing  85-86 bushing? Hope this makes sense.
Are the gears the same? Is it just the cover that is different? I was told that the 86 and up was a better setup than the 85.
« Last Edit: December 03, 2014, 10:44:57 AM by mrtwidster1 »
« Reply #1 on: December 03, 2014, 11:27:06 PM »
The gear is different and the shaft is also on the 88/89
Offline All250R
« Reply #2 on: December 04, 2014, 03:58:57 AM »
The shaft and gear have a wider contact area between them on the later model setup is the main difference.
