Author Topic: The Aftermath, Carnage! :culpability:  (Read 17320 times)
« Reply #30 on: January 31, 2015, 01:38:12 PM »
Whuuuuu, thank goodness.
Not entirely though, check the roundness above & below the balancer cavity, got two bulged out places. Be sure to check for flatness & use a heavy coat of sealant going back together.
Todays the day Fred, mail runs kinda late though.
« Reply #31 on: January 31, 2015, 01:41:54 PM »
ya almost looks like its alittle distorted near the balancer area. might just be the camera angle though
« Reply #32 on: January 31, 2015, 03:51:20 PM »
Your right Neil. You can see that from 900 miles away. How's that going to effect anything? How bad is it?
« Reply #33 on: February 01, 2015, 11:37:00 AM »
Is that the only cracked place on the right side half ?, what about the left side.
I know only a patch, would be good for just so long & the high dollar pocket folks will say replace them both, but its your money that will have to spend when just a little JB Weld would seal up the crack.
I would be thinking more about, if it has deformed the sealing surface for the gasket, thats why I was saying a good heavy coat of sealant on the gasket to fill any deformity.
Theres alway, V the crack, try to press the bulge back in shape & weld, but then you have to surface the gasket area back flat because the welding will push & pull the case.
Nothing came Saturday.
« Reply #34 on: February 02, 2015, 12:58:21 PM »
That's the only crack. I can fix that up. Out for delivery today Neil.
« Reply #35 on: March 28, 2015, 09:13:30 AM »
Did some testing with, JB Weld. Test sample sat in Honda HP tranny fluid, for 6 weeks. No change in appearance. Then I heated the sample in the fluid, [MENTION=677]250[/MENTION] degrees for 2 hrs. Still no visible changes.  I sealed the crack up. Going to give it a whirl.
