Author Topic: what did you do to your R today?  (Read 142726 times)
« on: July 17, 2013, 10:29:15 AM »
After riding last weekend and fouling a new plug, I decided I should change my pilot jet :)
I know it's nothing kewl....But maybe you guys did! So please share :)
« Reply #1 on: July 17, 2013, 10:33:53 AM »
adjusted the floats as rsss396 suggested and checked all my grounds for a clean/rust free connection.  also, modified my new swinger for a chain slider and have it at powder coater; almost forgot, having my shocks serviced.  itching to ride i must say.
« Reply #2 on: July 17, 2013, 11:36:21 AM »
Thought about it sitting in the the toy hauler in the storage yard. Looked on Powder By The Pound for something that matches what I want to do.
Does that count?
« Reply #3 on: July 17, 2013, 11:40:28 AM »
Re-seated the beads on my HiPers, both front were leaking but now i've got em nice and even and torqued properly.
Next is to figure out why my shift shaft seal is leaking tranny oil like a sieve. Brand new seal and no wear grooves in the shaft?????
« Reply #4 on: July 17, 2013, 11:55:14 AM »
Quote from: jcs003;4277
modified my new swinger for a chain slider and have it at powder coater; john
 Wheres the pics of the modification?
« Reply #5 on: July 17, 2013, 12:04:57 PM »
Quote from: Tbone07;4295
May be just a bad seal from the git go?? Mine leaks also...but it was a used motor.
« Reply #6 on: July 17, 2013, 12:05:57 PM »
Quote from: Rupp250;4294
Does that count?
Sure does! Lol
« Reply #7 on: July 17, 2013, 12:09:13 PM »
Got bearings in my cases,assembling the trans while waiting on parts from Honda.
« Reply #8 on: July 17, 2013, 12:18:30 PM »
Is the shift shaft bent? If you put  a new seal in try  putting sealer in the boss before you install the seal into it.
« Reply #9 on: July 17, 2013, 12:29:19 PM »
Quote from: Pumashine;4299
here it is.  pic isnt great but the welds or ok.haha
[ATTACH=CONFIG]728[/ATTACH]
Offline nico
« Reply #10 on: July 17, 2013, 02:56:06 PM »
All I did was order some new Steamline brake lines and a TM Designworks Super Protector for the 86's new +4 swingarm.  I have been thinking about machining my own swingarm guard out of Delrin though...   Maybe this weekend, I can have the 330R and 450R up and going.
« Reply #11 on: July 18, 2013, 01:19:34 AM »
I had one do that.  My problem was the hole was egged out where the shift actually comes thru the case.  New seal would not fix this even with some sealer on it.  The shift shaft would move around too much in it's bore.  I took a good punch when the seal was removed and peened around the shift shaft on the aluminum to tighten it up.  If that makes sense.  It worked for me.
« Reply #12 on: July 18, 2013, 01:55:13 AM »
Yes, that makes sense. You cold formed the egg shape back to round to support the shift shaft. If the surface the seal goes into is broken or has been repaired the seal just spreads the crack open allowing the thin tranny oil to come through. Sometimes can be fixed, but sometimes the motor has to come out.
Offline Sky
« Reply #13 on: July 18, 2013, 12:19:30 PM »
I just received my new chain slide, lower slide and new case saver and chain. All of which were destroyed last weekend when the chain slide jammed between the front sprocket, chain and case saver. Bent the lower case saver bolt but cracks the case!! Sooooo close to cracking case holes for the case saver bolts. Hopefully the new one piece will do better than the jaws style that wraps around the swing arm.
So now time to assemble and get ready for Silver Lake on the 27-28.
Offline Victork
« Reply #14 on: July 18, 2013, 12:43:55 PM »
I just looked mine over trying to determine what the best color combos would be for when i powder coat everything this winter. Its taking a great deal of patience for me not to tear this thing down now. She runs fantastic and i need to ride her while it ri
ding season imo
