Author Topic: what did you do to your R today?  (Read 143222 times)
Offline jadleybray
« Reply #300 on: August 25, 2014, 03:24:44 PM »
Stretched DT out this weekend!!!
« Reply #301 on: October 14, 2014, 01:40:12 PM »
Finally got to install the new case saver and went up to a 14 on the counter shaft sprocket.
Thanks to Tony for the blasting on the cover and the-steve-man for the cover!
Offline SARON81
« Reply #302 on: October 14, 2014, 02:22:22 PM »
I love those UPP case savers....wish I would've found them earlier.... they would've saved me a case!
I've done quite a bit lately. New (to me) polished 310 sleeved stock cylinder, 38mm Air Stryker, CR250 Rad Valve, new Paul Turner Eliminator pipe, new polished stator cover, new D.I.D chain, some 23" tires for trail riding, and a new polished kicker and shifter. It runs pretty strong now. :cool:
Offline Pricecheck
« Reply #303 on: November 03, 2014, 02:18:49 AM »
After blowing my motor and finding a crack at the lower motor mount I decided to order one of Tony's complete gusset kits.
Today I started cutting off all of the unneeded mounts and tabs and came up with a plan to mount my rear shock reservoir behind the radiator, mount the cdi and coil under the tank behind the radiator, minimize the petcock mount since I'm not using a head stay and reroute my radiator overflow hose to just above my pipe so when it overflows it'll steam.
Pics aren't too descriptive but you'll see the raw metal spots as I made progress. I'll have to repowder after it's all complete.
After the vin picture was taken i reduced the size of the plate so it can fit in the spot shown. The whole stock reservoir mount will be removed as will the stock tool box mount.
Offline Pricecheck
« Reply #304 on: November 03, 2014, 02:22:25 AM »
Dan's poly seat grommets also has me thinking of putting my router to use. I'll be making poly grommets for that along with chain sliders and rollers. I'll also be welding on pro peg nerf bar mounts to use with whatever nerf bars I purchase shortly. The mounts will be welded to minimize hardware needed.
« Reply #305 on: November 03, 2014, 04:50:38 PM »
Put most of them away so I can focus on finishing my 87 build this winter.
Offline aberegg05
« Reply #306 on: November 03, 2014, 06:15:17 PM »
How do you keep up with all those Rs? I can't keep up with just one.
« Reply #307 on: November 03, 2014, 07:07:10 PM »
Quote from: aberegg05;45411
It isn't easy sometimes.  I have a on-going list on what needs to be fixed on each one.  One good thing is though when one breaks you can still ride!
Offline Pricecheck
« Reply #308 on: November 04, 2014, 12:29:53 AM »
As much as I debated on welding tonight, I still did some. Not happy with my welding due to me not getting the frame completely clean in the first areas. It'll def hold though.
Here's my vin tab welded up (doesn't need to be strong) and a pic of my coil/cdi/ground/rad overflow hose. The cdi will be zip tied in place using the two brackets it rests on. The tab next to it is for the ground. This will keep all of my wiring tidy.
Offline Victork
« Reply #309 on: November 10, 2014, 10:10:04 AM »
My bike has been apart since about mid summer id say atleast. I mostly took it apart to gusset and powder but theres other things that it needs but its Finally going back together. Got a good majority of the front
end done yesterday. The pictures werent sideways in my phone before i uploaded them?
Offline Pricecheck
« Reply #310 on: November 10, 2014, 01:24:07 PM »
Nice victor. I really like that houser stem in red and the sticker running up it.
Nice rich red powder. I'm happy it's finally coming back together.
Offline Victork
« Reply #311 on: November 10, 2014, 01:39:12 PM »
Thats not a sticker, it looks like houser powdered the letters on some how but i do like the stem too thanks
Quote from: Pricecheck;45752
Offline Pricecheck
« Reply #312 on: November 10, 2014, 01:41:35 PM »
Damn. That's even better if you decide to run a stabilizer. My CCP pulled so stickers off but it's no big deal. Keep the pics coming.
Offline duff man
« Reply #313 on: November 10, 2014, 11:15:34 PM »
I got my motor upgrade in the mail today from Eddie Sanders. I can't wait to get to work on it. Eddie threw in a pile of extras including a jet wrench, coolant temp gauge, throttle cover, and a case saver!
Offline oldschoolr
« Reply #314 on: November 10, 2014, 11:24:53 PM »
That's awsome,  Eddie is the man.
