Author Topic: what did you do to your R today?  (Read 142445 times)
Offline JasonB
« Reply #60 on: December 09, 2013, 10:51:13 AM »
sent my crank off with my brother to have the new proX rod pressed into the stock cr500 crank. last tuesday I shipped off my cases to Adam Millar at MRE to have the TWIRP port job started on. Hope to have this R back up and running around 1st of the year if things go smooth
ATC500R
ATC310R
Offline chrisr
« Reply #61 on: December 09, 2013, 12:04:26 PM »
Nothing............waiting on parts to get shipped in from the west coast.  Damn weather has them running behind.
« Reply #62 on: December 09, 2013, 12:50:29 PM »
Pulled Duncan motor out of my 88 so I can put it in my project 87.  Put project 87 motor in my 88 as it will be my trailrider and it is the only motor I have that doesn't need race gas.  Twisted off exhaust manifold bolt and had to drill/tap it out.  Smashed my middle finger on my left hand in the process.  Also put a new chain slider on my 88.....was not one on it when I bought it.
Offline jamieg45
« Reply #63 on: December 09, 2013, 03:55:17 PM »
Quote from: red88r;19513
Sounds like a good productive day but bad on the fingers. Atleast you have a warm shop to work in bud.
01 Lsr 250r
00 Walsh 250r
« Reply #64 on: December 09, 2013, 04:52:55 PM »
Saturday i started tear down on my wifes 86....Lots of cleaning to do there. I dont think this thing has ever been taken apart fully(frame is painted but very poorly, im pretty sure it was taped off). I cant even budge the nut on the swinger bolt by hand, Air will come in handy.
« Reply #65 on: December 09, 2013, 05:20:15 PM »
Quote from: jamieg45;19550
Yes I don't know how I ever got anything done in my gagage by my house....no heat or insulation.  Ran a turbo heater and froze!  Been letting my Labs stay in the shop overnight because I feel bad for them out in the cold.
« Reply #66 on: December 09, 2013, 06:35:01 PM »
Quote from: ytman;19068
What'd you get?
[ATTACH=CONFIG]2624[/ATTACH]
rear grab bar
[ATTACH=CONFIG]2625[/ATTACH]
Offline Higgy87trx425
« Reply #67 on: December 09, 2013, 07:35:14 PM »
I bought a Cr250r ignition adapter plate from ESR and new ASV levers!!
« Reply #68 on: December 09, 2013, 07:51:49 PM »
Are you going to do the 02 cr Higgy?
Offline fx4pitrone
« Reply #69 on: December 09, 2013, 08:13:41 PM »
I bought a complete 310 motor and trx 5 pipe ready to drop in!
« Reply #70 on: December 09, 2013, 11:53:04 PM »
Polished a antifade I just bought and polished a Duncan silencer.  Removed mud,rust and carbon from the pipe.
Offline Pro-Fab
« Reply #71 on: December 10, 2013, 12:35:11 AM »
started prepping my cases for the new Hot Rods crank and full bottom end rebuild. Still have to remove all paint and repaint (going with the dark silver color). Dropping cylinder piston and dome for bore hone and reshape. Gotta swing by to have a bad repair fixed on my left case tomorrow. during the engine rebuild phase I am going to rearrange my modifications to my 86 frame and the rear engine mounts.
« Reply #72 on: December 18, 2013, 03:05:59 AM »
Quote from: sameltoe;19565
No, I found a 01 Cr250 ignition. I got everything mounted today except for the CDI. I gotta figure out how I'm gonna secure it down to the frame!
 Thanks Higgy!
Offline jamieg45
« Reply #73 on: December 18, 2013, 10:00:21 AM »
Let's see, I have been testing get stators. Messed up the flywheel nut and the threads on the crank, will be fixed today. Got a esr cr adapter plate so I hope to be getting the whole ignition installed when the plate comes in. Took the stator covers off both R's to re polish them. And I will update when I have other things I have done getting closer to the July silver lake trip.
01 Lsr 250r
00 Walsh 250r
Offline trx88
« Reply #74 on: December 19, 2013, 06:49:46 PM »
mounted a rebuilt rear i bought off ebay. springs black just like my fronts
really coming together, yesterday i dropped off a radiator to get it welded on..
