Author Topic: OEM cylinder aftermarket head?????????  (Read 6512 times)
Offline trx250scar
« on: January 17, 2015, 01:11:18 PM »
Does anyone know if esr makes a head for an oem cylinder. Seems I had saw them before. Now when I look all I c is for pro x type cylinders. I am putting an OEM motor in my r and looking for something with better cooling,  o ring instead of head gasket, and a dome so I can get more compression and  run race fuel.
Offline sanddad21
« Reply #1 on: January 17, 2015, 01:23:16 PM »
Led may be able to help you out. Give them a call
« Reply #2 on: January 17, 2015, 02:03:09 PM »
Does the cool head offer different domes?
« Reply #3 on: January 17, 2015, 02:17:04 PM »
Quote from: F-Red;48850
Yep, I've seen dome sizes from 18-22cc.
Offline trx250scar
« Reply #4 on: January 17, 2015, 02:19:18 PM »
Coolhead with an oring is not an easy find. Most reguire gasket. I do not know for sure but I bet cool heads with o rings have been machined that way. Not sent from factory with o ring.
« Reply #5 on: January 17, 2015, 02:21:58 PM »
If you disire this application, you could have both machined for o-rings.
« Reply #6 on: January 17, 2015, 11:18:59 PM »
Machining a head for 0-rings is a no-brainer.  Setting up the head for a particular engine takes some time.  Unfortunately there is a lot more involved in setting up a head for race gas than selecting a head with a particular volume!!!!!!!!!!!
« Reply #7 on: January 18, 2015, 12:43:45 AM »
Quote from: trx250scar;48853
I heard that o-ring pro design cool heads were kind of rare but I have one that I got new back in the 90's that is factory o-ringed. I sold one I got in a parts lot that was also factory o-ring & had pat pend stamped on it. Should of kept that one for nostalgia.
« Reply #8 on: January 18, 2015, 10:05:08 AM »
Why not talk to a reputable builder and just have your stock head cut and o-ringed for what you want?
I run one like that.
Offline trx250scar
« Reply #9 on: January 18, 2015, 03:26:41 PM »
Not a bad idea.I honestly had never seen an OEM head that way.
Offline jadleybray
« Reply #10 on: January 20, 2015, 06:53:50 PM »
for all intensive purposes, any "gasket" type head can be cut to accept orings instead
This is an OEM cylinder with a coolhead, oringed by JDI Racing
Offline trx250scar
« Reply #11 on: January 20, 2015, 07:18:51 PM »
Nice. I am going to look into it with a builder
