Author Topic: Wossner Piston  (Read 10671 times)
Wossner Piston
« Reply #15 on: January 23, 2015, 09:54:36 PM »
it was never about deviating from what the manufacturer recomends. was only trying to get people to look beyond the end of their nose. IMO the internet and most websites in general have done a great injustice to less knowledgable people. urban legend says a bigger piston always needs more clearance and forged piston always needs more clearance. yes, maybe, sometimes. got 2 bikes in the garage with pistons well over 90mm that require less than .0025 of skirt clearance per the manufacturers specs.  also have smaller pistons that require above .003. how could the much larger piston get by with less clearance. i think the answer is simple. the composition of the piston, its design and the bore material, operating conditions factor in here as well. after using aluminum bores with nikisil i wouldnt have it any other way. frankly i feel like puking when i see a iron lined cylinder
Wossner Piston
« Reply #16 on: January 23, 2015, 10:19:57 PM »
ryans thread had nothing to do with taking more material off the big end of the rod. no one in this thread said anything about bigger pistons needing bigger clearances compared to smaller pistons.
your arguing with yourself.
and still with the amsoil bs? make like elsa and let it go lol.
Wossner Piston
« Reply #17 on: January 23, 2015, 10:43:16 PM »
Quote from: JesseA420;49242
Lmbo!!
Seems he is upset no one wants to listen to him. when will we learn that we are the stupid ones and that he is trying to educate us?
Offline hub97119
Wossner Piston
« Reply #18 on: January 23, 2015, 10:50:35 PM »
85 stock Cyl. at 67mm bore  Wossner specs - 66.94 piston dia. with a .06mm clearance. My son and I are building (re-building ) an 86 for his senior project so trust me, he will run the piss out of this
Wossner Piston
« Reply #19 on: January 23, 2015, 10:57:59 PM »
I would stick with the manufacturer 's recommendation, Ron.
Offline hub97119
Wossner Piston
« Reply #20 on: January 23, 2015, 11:02:33 PM »
I'm thinking the same...thank-you again gentlemen
