Author Topic: help please!  (Read 8937 times)
help please!
« Reply #15 on: January 23, 2015, 09:35:36 AM »
Cutback on the fuel to it. Go down to middle clip on needle and start going down jet sizes one at a time.
Go through normal check up stuff such as cleaning air filter, checking wire connections, grounds, reeds, and make sure all carb boots are on tight!
help please!
« Reply #16 on: January 23, 2015, 09:36:28 AM »
Really does sound like your stator is going out. Can run at idle but does not have a powerful enough spark to run full throttle. I hope you have put a new plug in.
help please!
« Reply #17 on: January 23, 2015, 09:39:16 AM »
I switched from 40:1 to 36:1 & had to lean my carb a little when I made the change.
Offline kevin
help please!
« Reply #18 on: January 23, 2015, 09:43:58 AM »
Ok thanx guys going to try to locate sum jets today and see what I can do
Offline kevin
help please!
« Reply #19 on: January 23, 2015, 09:46:10 AM »
Yes new plug and clean uni filter.
