Author Topic: Front wheel offset  (Read 5144 times)
Offline Grande huevos
Front wheel offset
« on: January 24, 2015, 02:27:13 PM »
I have plus 2 arms on my quad because I mainly ride tight trails and I'm getting ready to buy some new wheels and dune tires and would like to widen her out a bit. These will only be used as dune wheels so what offset should I go with?? Any recommendations would be great
Offline CR500R
Front wheel offset
« Reply #1 on: January 24, 2015, 02:35:41 PM »
For dunes 3 plus 2 is as wide as you wana go, any more and you will get bad bump steer.
I prefer 4 plus 1 for MX and woods riding.
Front wheel offset
« Reply #2 on: January 25, 2015, 08:57:00 AM »
Quote from: CR500R;49271
So what exactly do those numbers mean? The higher the second number the deeper the dish for wider stance?  I see the tears are 3+5
Front wheel offset
« Reply #3 on: January 25, 2015, 09:38:59 AM »
Nice reference page.
Front wheel offset
« Reply #4 on: January 25, 2015, 12:42:02 PM »
I ride dunes 24/7 and use 4+2 with +2 a-arms. This feels so right and I don't have any problems with bump steer. Where does anyone get bump steer on flat sand?
Front wheel offset
« Reply #5 on: January 25, 2015, 09:28:39 PM »
wheel offset has nothing to do with bumpsteer
Front wheel offset
« Reply #6 on: January 25, 2015, 11:20:06 PM »
The height of the tire you are going to use has an effect on what offset is needed. If you are going to run a taller than stock a 3+2 would be acceptable ,if you are running a short mx tire a 4+1 would be needed. If you are running the oem tire,the oem wheel is best. Honda did not make a mistake with the oem setup.From the factory your tires turn slightly off the centerline of the ball joints, moving it to exactly center isn't necessarily a good thing and moving it further away from center is even worse
Front wheel offset
« Reply #7 on: January 25, 2015, 11:28:06 PM »
If you can,picture in you mind a shorter or taller tire and see were it moves the centerline of wheel closer or further away from balljoint centerline
