Author Topic: 2 guys from West Michigan going to glamis, local guy invited  (Read 13324 times)
Offline Dirt man
« Reply #15 on: January 27, 2015, 10:23:11 PM »
When you stop doing things for fun you might as well be dead.
It goes fast over bumps too!
« Reply #16 on: January 27, 2015, 11:33:35 PM »
man O man! Probably going right by on Interstate 80 threw Iowa too huh?
Offline Dirt man
« Reply #17 on: January 28, 2015, 01:43:16 AM »
No, Southern route through St Louis, OK, TX, NM, AZ, CA.
Offline silverlake250r
« Reply #18 on: February 22, 2015, 01:28:49 PM »
https://www.youtube.com/watch?v=lQM0IeZOjms
Some GoPro clips from our adventure.
2002 Roll Design Lobo MX
« Reply #19 on: February 22, 2015, 03:20:18 PM »
Cool R dune fun vid. Looks like a blast until the trouble. Glad you guys had a good trip.
« Reply #20 on: February 22, 2015, 03:28:29 PM »
Survived most of the trip with the good bikes running. Time to go bigger!
Offline supernutt
« Reply #21 on: February 22, 2015, 08:01:05 PM »
All I can say is WOW!!!  My first impression is untamed territory.....What a difference from the dunes here.  I am not used to NOT seeing thousands of people like at silver lake.   That was an awesome video and i like the videos alot better when there is no music playing just like this one!!!  Looking forward to seeing you again at silver lake.....
« Reply #22 on: February 22, 2015, 08:30:11 PM »
Thanks man! Yes, its a lot of virgin sand but not a lot of WOT because of all the unknown dropoffs and unpredictable soft sand. I wanted to add, the reason I locked up was a clogged gas tank vent....its dustier sand and after days of riding I think it filled up and I ran my bowl out of fuel. I had 75-100 hard sand dune hours on that top end though, time for a new one anyway.
Offline Flyin_250r
« Reply #23 on: February 23, 2015, 09:56:28 AM »
Looks like a wild time man
So what's the next setup going to be?
« Reply #24 on: February 23, 2015, 10:32:36 AM »
Quote from: silverlake250r;50560
We have had replaced dozens of pistons in engines because of the little billet piston shaped check valves that guys put on the  end of their fuel tank vent lines.  The spring in the check valve is too strong and does not allow the fuel tank to vent properly.
Carburetor tuning is much more critical when running the big dunes than bikes tuned for smaller dunes and woods bikes where the periods of wide open throttle are less.
Offline Dirt man
« Reply #25 on: February 23, 2015, 11:37:53 PM »
I actually run more wide open throttle at Silver Lake then I do glamis. Other than the sand highways most of the time we are grunting around at glamis. Yes the big bowls and walls we run wot but not nearly as long as what I do at SL. Marcs bike lasted 4 big days at glamis. I truly believe it was a gas tank vent problem.
« Reply #26 on: February 24, 2015, 06:29:53 PM »
its funny you guys mention those little buggers, the last time i rode this year i picked one up from a vendor at the ride area, as soon as i did my bike was catching a lean condition but i didnt put 2 and 2 together. definately pulling it off right away.
Offline Dirt man
« Reply #27 on: February 24, 2015, 07:18:54 PM »
Arlan says stay away from them. I'm a idiot and still run one, I can't stand the hose and trying to find a place for it. Also when removing the gas cap having to deal with it. Maybe I'll learn my lesson some day.
