Author Topic: Clutch Problem - Not Engaging  (Read 3562 times)
Offline Sean86250R
« on: February 01, 2015, 12:20:35 AM »
Hello,
I need some help.  I recently took the clutch out of my 250R because it wouldn't find neutral except when not running.  So, I believed the basket may need filed and it did.  So, I filed the basket ears and seemingly did it right.  It seems to have an 89 upgrade clutch with the flat needle bearing on the push rod.
When I had it apart, I do not think there was a washer/spacer between the flat needle bearing and the pressure plate, so I (excuse my ignorance on this one) used a cut washer that seemed the right size and put one in...
The reassembly went fine, I may have overtightened the clutch springs from what I can tell, but there were no issues.
When I fired it up.... it will shift, BUT the clutch will only grab enough so the quad just barely moves...like barely moves at all.  So, for whatever reason, I made things worse....
Two questions, did I screw up by really tightenting the clutch springs a lot and I am guessing I better get the actual washer/spacer that goes between the flat needle bearing and the pressure plate.
Any thoughts would be great.
Thanks
Sean
« Reply #1 on: February 01, 2015, 01:52:29 AM »
Unless you stripped the bolt holes, over tightening is not causing your issue. My guess is the washer is too thick. If I recall correctly it is about1mm thick.
 Is your cable adjusted right? You should have ~.125" - .25" of free play at the lever.
Best regards
-Jason
Offline Sean86250R
« Reply #2 on: February 01, 2015, 02:05:22 AM »
Thanks Jason.  Cable ought to be good.  Brand new and was working fine before I took it apart.  The washer I put in couldn't have been much more than a mm, but maybe.  I'm going to take it back apart and check everything out.
I swear there wasn't even a washer in there when I took it apart, but the needle bearing would eat into the pressure plate wouldn't it?
« Reply #3 on: February 01, 2015, 02:41:51 AM »
Make sure theres a little play at the actuator arm. The 89 upgrade includes a pressure plate, are you sure you have the 89 plate because it has a deeper pocket machined for the bearing. I had a problem with mine not engaging when I did the clutch upgrade with used parts & ended up having to grind down the push rod a little at a time to get the clutch to engage all the way. I'm not saying the way I did it is right but it worked.
« Reply #4 on: February 01, 2015, 12:50:33 PM »
washer has to be to thick and you could put all the freeplay in cable that you wanted and it would make no diff,I think I have that washer on the bench if you needed measurement
