Author Topic: 400EX spindle onto a 86?  (Read 3406 times)
Offline Rupp250
« on: February 17, 2015, 10:22:12 AM »
What does it take to do it correctly? I have 2 sets of 400EX spindles sitting here that I could use. Plus I have 2 86's. Perfect match, right?
DUNER -86 250R  Flinstone
Offline Burns363R
« Reply #1 on: February 17, 2015, 10:53:15 AM »
You must either use 400ex or yfz calipers, or buy the 400ex/250R adapter brackets for the calipers.
You must run 400ex hubs, or if you want to use 88/89 hubs you have remove or install the tapperd spacer between the bearings.
Offline Rupp250
« Reply #2 on: February 17, 2015, 01:52:38 PM »
Where are these said caliper brackets? I'll have to look into the hub situation because one bike is stock and the other has LSR's. Not sure which year lsr though.
Offline Burns363R
« Reply #3 on: February 17, 2015, 01:56:04 PM »
http://www.ebay.com/itm/trx250r-front-brake-caliper-adapter-brackets-400ex-spindle-trx-250r-brakes-blue-/231461565824?pt=Motors_ATV_Parts_Accessories&hash=item35e42f3580&vxp=mtr
I think i saw some used the other day on facebook, not sure they where any cheaper.   They are an expensive option.  Cheapest is to do the YFZ caliper that bolts direclty to the 400ex spindle.  Gives you dual pistons, and much cheaper.  I run 400ex spindles on both my 250R's and have the adapters to use the stock calipers.  No complaints here.
« Reply #4 on: February 19, 2015, 12:54:39 AM »
Steve was selling the adptors. They have since been sold.
