Author Topic: My '86 project after a LONG vacay from 250R's!  (Read 23737 times)
Offline mandom250r
« Reply #45 on: March 30, 2015, 10:23:01 PM »
Quote from: Jimbo45;52408
The head gasket is a .040" Cometic 3 layer gasket.
ah hell...maybe the resurfacing will compensate for the thick gasket, or take a base gasket off
Offline Jimbo45
« Reply #46 on: March 30, 2015, 10:37:26 PM »
Quote from: mandom250r;52410
Yeah, I am gonna check squish in the morning, and may end up pulling one of the base gaskets, if it figures out to have enough clearance that way.  I should be able to do all that without removing the head.
Offline Jimbo45
« Reply #47 on: March 31, 2015, 01:33:32 PM »
Things have escalated....
Offline Jimbo45
« Reply #48 on: March 31, 2015, 01:34:08 PM »
« Reply #49 on: March 31, 2015, 01:42:28 PM »
ohhhh sooo nice
« Reply #50 on: March 31, 2015, 04:56:51 PM »
I'm jealous
Offline Jimbo45
« Reply #51 on: March 31, 2015, 11:48:13 PM »
Quote from: hickwheeler;52455
I'm jealous
I got my '88='89 style headlight collars fabbed up, thanks to your measurements!
Offline Jimbo45
« Reply #52 on: March 31, 2015, 11:50:53 PM »
Elkas are installed!  For a few minutes, I was trying to figure why the rear shock res hose was so dang long, and was trying to mount it in the stock location.  After googling some pics, I noted that it is intended to mount up front.  Sweet!  More pics to come tomorrow, after a couple more heat cycles on the new top end, and I get plastic installed, and it all cleaned up!
Offline Jimbo45
« Reply #53 on: March 31, 2015, 11:54:22 PM »
Question on the rear Elka shock.....it makes a "clunk" about 2/3 of the way through the stroke.  It sounds like one of the plastic collars in between the spring stages is catching on a coil as the shock compresses or something.  Is that normal?  Its not that big of a deal, but it is a noticeable thud, and I can even feel it.  Weird.
Edit to add:  After setting the sag (it was way too soft out of the box), the clunk went away!
« Last Edit: April 02, 2015, 12:41:22 PM by Jimbo45 »
Offline Jimbo45
« Reply #54 on: April 01, 2015, 10:10:58 PM »
Well, its done for now.  I will probably powdercoat the bumper, grab, and nerfs black  (or charcoal, if I redo the frame pc too) next winter, but for now its done.  I didn't clean it up yet, but you get the idea.  Thank you all for all your help and patience.  I could not have done it without you.  It is ready to GO!  I put a few heat cycles on the engine, and have it jetted a bit rich for the first break in ride.  Gonna set sag tonight and get ready for its maiden weekend!
Went through and checked/replaced/fabbed all the:
Bearings
Brakes
Master cylinders
Hiper Wheels
Fasteners
Built a factory style wiring harness for lighting
Added Headlight and tail light and OEM lighting kill switch
Top end
New Airstriker carb
Gaskets
Ignition
Hubs and bearings
Airbox and filter
New Elka suspension
« Reply #55 on: April 01, 2015, 10:21:07 PM »
Very nice jimbo. You should be proud.
Offline Jimbo45
« Reply #56 on: April 01, 2015, 10:43:40 PM »
Quote from: etccb;52542
Thank you sir.  I can't take all the credit though.
It is a budget build compared to what a lot of you guys have, but it will be perfect for what I need for now.  Plus, there is always another project that can be done right? :)
« Reply #57 on: April 02, 2015, 07:55:59 AM »
looks great man, enjoy!
Offline zcarlson12
« Reply #58 on: April 02, 2015, 09:11:49 AM »
Excellent job. Pics and vids of the ride stat!
« Reply #59 on: April 02, 2015, 10:45:24 AM »
Quote from: Jimbo45;52544
Budget builds don't have ELKA's:rofl:
