Author Topic: Recommend a quiet silencer for my Sparks MX pipe  (Read 8359 times)
Offline Jimbo45
« on: March 05, 2015, 03:05:14 PM »
My sparks silencer is more than then years old.  I know I could repack it, but IT IS LOUD.  I really want a quiter silencer, that I can add a spark arrestor to, if needed down the road.  Any recommendations on a quieter silencer that I can add a spark arrestor too, that doesn't cost an arm and a leg, that will work with the Curtis Sparks MX pipe?
Offline fx4pitrone
« Reply #1 on: March 05, 2015, 04:04:32 PM »
Fmf turbine core w spark arrest or might fit your needs.... That's what I'm gonna run w my esr 5 pipe....
Offline Jimbo45
« Reply #2 on: March 05, 2015, 04:32:54 PM »
Quote from: fx4pitrone;51036
I wonder how these compare, dB wise, to say, a Cascade silencer?
Offline fx4pitrone
« Reply #3 on: March 05, 2015, 05:08:10 PM »
Not a clue
Offline mennis1971
« Reply #4 on: March 05, 2015, 06:15:25 PM »
I've heard  that the Cascade is quieter. I forget who all owns one. Pumashine and or some of the Mich guys should know. We don't have to deal with that issue here in Okla.  Pro Circuit makes one also BTW, but I'm pretty sure that the Cascade is sup to be the most quiet one that is spark arrested.
Offline Jimbo45
« Reply #5 on: March 05, 2015, 07:05:07 PM »
Well, I had a Cascade ordered this afternoon, but realized you need to have the stinger bent and welded to the canister, for your application.  That is not in my realm of capabilities.  Ordered cancelled. :(
So, anyone know if the FMF turbine core2 will bolt right up to a Sparks MX pipe???????
Offline Jimbo45
« Reply #6 on: March 05, 2015, 07:31:25 PM »
...on another note, it seems I may have a big bore Curtis Sparks MX pipe....the O.D. of the end of the head pipe, where the stinger fits over, on mine is 1.130".  It seems the standard bore Sparks pipes are 1.115", from what I have read.  Maybe I need a new head pipe altogether, since mine is not a  BB, and only 269cc.  Dang, this is a mess.....
« Reply #7 on: March 05, 2015, 08:23:32 PM »
Standard pipes are 1" ID or 1.125 OD. Big bore are 1 1/8" ID or 1.250 OD. Your best bet is to use the Cascade silencer with the sparks stinger. The cascade comes with a flange. You would have to cut the sparks stinger and weld the cascade flange to it.
Offline Jimbo45
« Reply #8 on: March 05, 2015, 08:40:08 PM »
Sounds like I have a sparks big bore system.  Maybe that is why the powerband hits so hard.  Maybe I need to look for a different system all together....
« Reply #9 on: March 05, 2015, 08:48:04 PM »
I got the fmf spark arrested q-silencer with a trx5 pipe & it's 95db. I heard the cascades are quieter though & flow a little better than the fmf. One thing about the q-silencer is it's long & I had to shorten the stinger so it didn't stick out past the grab bar & look gay.
« Reply #10 on: March 05, 2015, 08:51:40 PM »
Quote from: Jimbo45;51042
That is standard. A big bore would measure 1.250" on the OD
Offline Jimbo45
« Reply #11 on: March 05, 2015, 08:53:29 PM »
Quote from: Pumashine;51049
Oh, yeah, I was reading that wrong.  Doh!
Offline Jimbo45
« Reply #12 on: March 05, 2015, 08:55:59 PM »
Ok, so does anyone know, or have an educated guess........would an FMF Turbinecore2 silencer bolt up to this Sparks MX pipe?  I do have a silicone clamp coupler thing I could use, if it wasn't perfect......
Offline supernutt
« Reply #13 on: March 05, 2015, 08:59:11 PM »
When I was trying out a sparks MX pipe, I am pretty sure I had it bolted up to my turbine core 2 silencer.  I agree with you, that sparks silencer is LOUD!!  I run TRX5 pipes now and I don't even run the ESR silencer with them..Just too loud for my liking.  I know the turbine core is not the quietest thing around, but it is a lot quieter than most silencers...
« Reply #14 on: March 06, 2015, 01:22:08 AM »
Jim i have a turbine  core silencer.  here is 2 pics  front  and back .it has some damage  from the rear caliper  hitting  it.
