Author Topic: Streamline 3 pc front braided set - location of "tee"  (Read 5800 times)
Offline 87cclR
« on: March 18, 2015, 05:38:04 AM »
Just wondering, for those of you who have used this kit. It includes a machined tee with a single mounting hole, where did you locate it? I'm planning on making a small adapter plate that will utilize the stock holes with an M6 hole drilled/tapped in between. Or am I better off drilling/tapping a new location for this and maybe using a weld nut in the frame? Thanks.
« Reply #1 on: March 18, 2015, 08:26:51 AM »
First question, what year frame do you have? I know they mount differently between the 86 frames and the 88-89 frames. I have the Streamline kit and I mounted them differently between the two year frames that I had. I think I have a pic posted of how I mounted the tee on my 88 frame. I ended up using a 90° fitting. Let me find the pic.
« Reply #2 on: March 18, 2015, 08:42:19 AM »
i dont think its a better off situation as both are viable options. if ur frame is finished just make an adapter plate, if it doesnt have a finish on it yet you have the option to drill and weld a nut on into the location u need, its really up to you how u want to do it.
Offline zcarlson12
« Reply #3 on: March 18, 2015, 09:09:14 AM »
If you haven't bought the 3 piece yet just buy dual lines and then you don't have to worry about a tee. Just another option.
Offline Jimbo45
« Reply #4 on: March 18, 2015, 09:46:50 AM »
Hmmm.  Mine is an '86, and came to me with the 3 piece streamlines.  I will have to look and see how it was mounted later today......
Offline 87cclR
« Reply #5 on: March 18, 2015, 09:50:29 AM »
Quote from: rablack21;51737
1987, from what I'm seeing here, I think I'll end up cutting off the old bosses and plug welding them. Add a welded in nut to the front side of the frame and add two small squares to keep the tee from moving. I'll try to post a pic once it's done. If you can find that pic, that'd be great.
Offline 87cclR
« Reply #6 on: March 18, 2015, 09:51:04 AM »
Quote from: Jimbo45;51744
Please do, I'd appreciate it.
Offline 87cclR
« Reply #7 on: March 18, 2015, 09:51:36 AM »
Quote from: zcarlson12;51743
Already purchased, got a great deal on them.
Offline Jimbo45
« Reply #8 on: March 18, 2015, 10:04:35 AM »
Quote from: 87cclR;51746
Gonna go pull it out here in a bit, and will try to get a pic for you.
Offline Jimbo45
« Reply #9 on: March 18, 2015, 11:08:43 AM »
Mine appears to have just bolted on to an existing bung.  Not sure it that was added or is stock though....
Offline 87cclR
« Reply #10 on: March 18, 2015, 11:17:47 AM »
Sweet, thanks for the pics. I'll post mine once it's done.
« Reply #11 on: March 18, 2015, 11:19:43 AM »
Those two bosses on Jimbo's pics are the factory locations for the stock brake lines.
Offline Jimbo45
« Reply #12 on: March 18, 2015, 11:23:57 AM »
Quote from: 87cclR;51751
No problem.  Will yours not simply mount up like mine?
Offline Jimbo45
« Reply #13 on: March 18, 2015, 11:24:53 AM »
Quote from: rablack21;51752
I figured so, but wasn't sure what was done to this frame before I had it.
« Reply #14 on: March 18, 2015, 11:27:38 AM »
Quote from: Jimbo45;51754
And some of those things change from year to year. The 88-89 same mounting area is different from the 86-87.
