Author Topic: Floating the ground for d.c. lighting.  (Read 9222 times)
Offline hontrx265r
« on: March 19, 2015, 10:36:52 PM »
Ive been asked to put a semi formal write up on how to float the ground on the 250r stator. For now Im going to just get it out of the stator and maybe later i can write something on rectifiying and changing output to d/c. Remember that "floating the ground" is much easier to think of as "isolating the ground" because on a standard atc/trx the lighting coil ground is grounding through the stator body and the path travels through the engine to chassis. (This is why there is only a lighting coil wire coming from the stator connection and not a ground wire.
    I start by feeding a length of wire down the sheath, and through the stock grommet (sharing one of the holes that is already punctured) this can be tough but if you cut the wire on a diagnal so it is sharp and use di electric grease or similiar it goes right through. I then unclip the harness from the stator and follow the same path up to the body.
Your unsoldering the stator coil wire from the "v groove" that is attached to the metal portion of the stator body. Some aftermarket stators have a coil wire in one groove and another wire soldered in the other set of grooves that are over the plastic portion. Remember its always the one attached to the metal portion "as its ground through chassis"
  Slide a piece of shrink over the new wire and solder it to the end of the coil wire that you unsoldered from the groove
  This 3rd pic shows how the wire is routed tight against the stator coil out of harms way from hitting the flywheel as it spins.
Hopefully this helps, this is the actual ground isolation. You now have 5 wires at the stator. Ill cover from there in another chapter.
Offline shreke
« Reply #1 on: December 26, 2015, 01:44:20 PM »
Did you ever post the follow up to this article? I have floated my ground and am ready to install a rectifier. Im using a kohler one that i was told would work but not sure how to wire it in.
Offline hontrx265r
« Reply #2 on: December 30, 2015, 07:18:32 AM »
No I have not, but basically in your rectifier you have two ac leads in. (Not polarity sensitive) that will be your original lighting wire and your new floated wire. The other two a pos and neg will be your d/c feed out.
Offline Quadracer1
Re: Floating the ground for d.c. lighting.
« Reply #3 on: January 20, 2024, 11:53:05 AM »
Hello,
I just wanted to follow up on this. Were exactly does the new ground wire you soldered in go to? Does it attach to the AC/DC regulator rectifier? If so where? I understand the lighting lead coming from the stator goes to the two yellow wires from the rectifier/regulator but where does the ground wire attach to?
Attached is the regulator rectifier im using.
