Author Topic: 85 Atc parts  (Read 3873 times)
Offline TRX250RACER
85 Atc parts
« on: March 28, 2015, 04:27:03 AM »
I have an 85 atc swingarm for sale.  It comes with a billet bearing carrier. The skid plate mounts have been removed before it was powder coated black. $135 shipped
Also I have a rear shock linkage that I believe is exclusive to the 85 atc. It is in very nice condition and it will come with the pictured. $35 shipped
Offline KASEY
85 Atc parts
« Reply #1 on: March 28, 2015, 09:48:43 AM »
that's not an 85 swinger,,,,  86 all the way,,,,,
Offline TRX250RACER
85 Atc parts
« Reply #2 on: March 28, 2015, 01:31:02 PM »
Quote from: KASEY;52269
How can you tell?
Offline jadleybray
85 Atc parts
« Reply #3 on: March 28, 2015, 03:36:25 PM »
Brake stay, 85 has the goofy mount on the side
Offline TRX250RACER
85 Atc parts
« Reply #4 on: March 28, 2015, 04:16:26 PM »
Quote from: jadleybray;52288
Ok well riddle me this... Isn't the 85 swingarm the one with the smaller diameter bearing carrier? This one has a small diameter bearing carrier. Or did both the 85 and 86 have the same carrier?
I don't know to much about the atc's so bear with me please.
85 Atc parts
« Reply #5 on: March 28, 2015, 06:02:24 PM »
Same carrier  different  bearings  inner diameter of bearings are smaller for 85 axle. is smaller. If I'm  not mistaking.
Offline KASEY
85 Atc parts
« Reply #6 on: March 28, 2015, 08:29:43 PM »
Quote from: thesmith87250r;52295
no you are mistaken,,,,  85 is one year on the carrier,,  all axle bearings (6908) are the same in all years,,  all axles are the same,, BUT  the 85 sprocket hub is different so it will not work in any other year,,, the 85 had a link arm from the caliper mount to the swinger 86 has the post like this one is,,,  the diameter of the clamping surface on an 85 carrier is 3 3/16"
Offline KASEY
85 Atc parts
« Reply #7 on: March 28, 2015, 08:32:51 PM »
after looking at the picture closer it MIGHT be AN 85,,,  if the post is not original and someone added a 86 caliper stay,,,,   which I have seen done in the past,,,   measuring the diameter of the clamping surface will tell the story
