Author Topic: Pro x cylinder  (Read 5237 times)
Offline Pj Uptmor
Pro x cylinder
« on: March 28, 2015, 12:21:52 PM »
I have  a pro x cylinder has a removable water neck fitting for the top water hose to the radiator. When I did a pressure test on the radiator.  I found it to be leaking. I applied red gasket sealer on it but it still leaks. Is there a gasket to buy r a different sealer.
Thank you
Paul
Pro x cylinder
« Reply #1 on: March 28, 2015, 01:43:56 PM »
Yes there should be a gasket between the top spigot and the head.
Offline Pj Uptmor
Pro x cylinder
« Reply #2 on: March 28, 2015, 01:56:20 PM »
Who would have this gasket?
Offline xTHUNDERCATx
Pro x cylinder
« Reply #3 on: March 28, 2015, 02:56:37 PM »
I think ESR sells them.
Pro x cylinder
« Reply #4 on: March 28, 2015, 04:20:44 PM »
You can get gasket material at your local auto parts store & make your own as another option. There would be enough material to make other gaskets as well.
Pro x cylinder
« Reply #5 on: March 28, 2015, 05:23:41 PM »
ESR does not sell the top spigot for the head. Eddie only sells the spigot on the side of the cylinder. I had a cylinder who's head was missing the top spigot. I ended up buying a used head just for the spigot.
The guys are right. For such a small gasket its cheaper and easier to make it yourself. Your local auto parts store should sell sheets of gasket material.
Offline Pj Uptmor
Pro x cylinder
« Reply #6 on: March 28, 2015, 06:24:25 PM »
I was thinking about making my own. Thank guys
Pro x cylinder
« Reply #7 on: March 28, 2015, 08:03:45 PM »
I've been told CPI dealers can get the spigot.
Offline Pj Uptmor
Pro x cylinder
« Reply #8 on: March 29, 2015, 08:23:24 AM »
Thanks guys..
Pro x cylinder
« Reply #9 on: March 29, 2015, 07:40:04 PM »
Three Bond #1211 sealant, apply a thin coat, bolt it all together & let it sit & cure out a whole day & night before adding any coolant to the engine. Curing time is the key to the sealant working as it should.
No silicone sealant is instant & needs time to cure out.
