Author Topic: Chemical strippers  (Read 33410 times)
Chemical strippers
« Reply #15 on: March 21, 2016, 02:46:18 PM »
Quote from: dem3500;65768
i use a propane torch quite often to heat up parts that im going to TIG. especially when im welding thick to thin or a old part when welding a new part to it like a replacement tab for a nerf bar or something like that.
Another good cleaner for aluminum is aluminum brite an acid based cleaner.
Offline dem3500
Chemical strippers
« Reply #16 on: March 21, 2016, 02:54:39 PM »
Quote from: Skeans1;65770
good to know. acetone also works well. i wipe down the filler rod before i weld.
Chemical strippers
« Reply #17 on: March 21, 2016, 03:21:51 PM »
Quote from: dem3500;65771
Acetone or thinner is great for wiping down for oils where as aluminum brite will strip paints as well as clean it.
Chemical strippers
« Reply #19 on: April 27, 2016, 04:44:39 PM »
Quote from: Skeans1;65773
The stripper also recommends acetone for washing parts after stripping. I use lacquer wash as it is cheap and does the same thing.
Chemical strippers
« Reply #20 on: April 27, 2016, 06:16:07 PM »
Tony i use the  same stuff works  great on paint  then i power wash it off . It won't get it all so i use the same brand in  a  rattle can an power wash agian.  I will post some pics tonight of the plastics i used it on
Chemical strippers
« Reply #21 on: April 28, 2016, 12:20:40 AM »
Chemical strippers
« Reply #22 on: April 28, 2016, 12:25:23 AM »
i tried the aircraft stripper first an it did not even bubble. this was some tough paint, till i used  the clean strip !
Chemical strippers
« Reply #23 on: April 28, 2016, 10:49:10 AM »
Quote from: thesmith87250r;67033
The good plastic paint is a 3 step process with a flexing agent. I noticed there was a gallon of clean strip that came with a spray bottle. That would work instead of using the rattle can.
« Last Edit: May 22, 2016, 05:27:30 PM by Pumashine »
