Author Topic: Sprocket / Rotor hub sealing surface diameters  (Read 3298 times)
Offline Tador
« on: April 11, 2015, 06:43:19 PM »
[TABLE=width: 99%, align: left]
[TR]
[TD]
[TR]
[TD]I bought a new bearing carrier for my R (1987), and the outer seals don't touch the seal surfaces on the sprocket hub / rotor hub. Was there different diameters over the years and someone has a different axle in it?[/TD]
[/TR]
[/TABLE]
If I know what the diameter is supposed to be I'll just turn it down and machine a ring the correct size and press it on. So... if anyone has a fresh hub laying around that they can mic the surface of that'd be awesome![/TD]
[/TR]
[TR]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
« Reply #1 on: April 11, 2015, 07:50:50 PM »
Quote from: Tador;52985
Sprocket hub looks to be 52mm or 2.047" in diameter
Offline Tador
« Reply #2 on: April 12, 2015, 10:52:05 AM »
That is bizzar.  Mine mics out at around 1.875.  Thanks much, I'll machine a ring for it.
« Reply #3 on: April 13, 2015, 01:07:25 PM »
What Brake Rotor Hub are you using ??? 250R & 450R are the same at 52mm Diameter. Give us a pic if you can. :)
Offline Tador
« Reply #4 on: April 14, 2015, 10:52:16 AM »
I honestly have no idea. It has an adjustable axle in it, but I'm assuming it must be from something else... 3 wheeler maybe? Who knows. I'll try to grab a pic on my lunch break, it's in the back of my Jeep.
