Author Topic: Need good transmission  (Read 10472 times)
Offline Trx428r
« on: April 19, 2015, 11:24:37 AM »
Does anyone have a good 88-89 trans or 85-87 trans in good shape they would like to sell? Or can anyone recommend anyone that sells transmissions? I'm working on a 431 puma build and am having trouble finding a good set of gears.
« Reply #1 on: April 19, 2015, 01:22:17 PM »
Is it just a few gears or do you need a whole transmission?
Offline Trx428r
« Reply #2 on: April 19, 2015, 02:09:02 PM »
I'll check with my builder this week, he said everything was pretty rough, have to see how much I really need
« Reply #3 on: April 19, 2015, 02:22:32 PM »
Dale the seller on ebay's Dirt factory parts out many 250r's. you can get a whole tranny for $200 then get if magnufluxed and Cryo'd for a little more.
Offline Trx428r
« Reply #4 on: April 19, 2015, 08:12:44 PM »
Quote from: Pumashine;53317
Thank you I will try them, just have had bad luck from random sellers on ebay
« Reply #5 on: April 19, 2015, 08:39:32 PM »
Quote from: Trx428r;53336
Another member here [MENTION=498]312R1[/MENTION] has really nice 250r parts for sale now and then
Offline Trx428r
« Reply #6 on: April 20, 2015, 12:47:48 AM »
Quote from: spiritaces;53338
I wish I knew this yesterday. I have 3 nice transmissions. Too late now i left town for work
Let me know when you get back I'm working on 2 builds might still need one. Thank you.
Offline Trx428r
« Reply #7 on: April 20, 2015, 12:49:43 AM »
Quote from: Pumashine;53337
Another member here 312R1 has really nice 250r parts for sale now and then
Thank you i will keep an eye out
« Reply #8 on: April 20, 2015, 12:23:37 PM »
Does LED still have the reinforced countershaft gears? You might want to look into some tougher ones for the Puma.
Offline 312R1
« Reply #9 on: April 20, 2015, 06:41:18 PM »
Thanks Tony,
I'm all cleared out until this winter. Back to work now.
Offline Trx428r
« Reply #10 on: April 20, 2015, 08:31:00 PM »
I found a set of new yukons and plan on cryo treating them, think they will hold up vs led 1-3
« Reply #11 on: April 20, 2015, 08:36:08 PM »
Quote from: Trx428r;53374
I been running 2 puma's for 6 years now on stock tranny's. Blew 2nd on one of them. Lil epoxy and another $150 tranny is a good fix.
Offline Trx428r
« Reply #12 on: April 21, 2015, 10:23:09 PM »
Quote from: Pumashine;53375
Maybe I'm worrying too much if stock is holding up good for you. Do you cryo treat your stock trannys?
« Reply #13 on: April 21, 2015, 10:55:45 PM »
Quote from: Trx428r;53493
Not until this 486 I am putting together now. Most important is to get first and second back cut so they do not slip out of gear when taking off.
Offline Trx428r
« Reply #14 on: April 22, 2015, 01:04:47 AM »
Quote from: Pumashine;53496
I have to Ask what is the 486? Is it based off a puma cylinder? And what is the bore and stroke? I have two transmissions coming so should be good for gears now with yukons. Already have some shiny stuff from you just need a reason to bolt it on. Just lost interest in the polonda.
