Author Topic: Homemade Tools  (Read 4426 times)
Homemade Tools
« on: April 26, 2015, 02:33:34 AM »
I needed something to clean the rust out of the floater pin bore on a rear caliper & couldn't find anything for the Dremel so I made this with 1/4" bar. I used a hacksaw to cut a notch about 1/2" deep, folded some emery cloth, chucked it in the drill & went to town. It worked great & cost me pennies:
Offline traxman
Homemade Tools
« Reply #1 on: April 26, 2015, 10:22:01 AM »
Hey Kevin, if your ever worried about metal on aluminum when doing something similar you can also use a used old 1/4 flag pole. Just cut it to your desired length and use a knife to make a slit for the emery cloth and put a couple wraps of electrical tape around the fiber glass to keep it from splitting further. I use this method a lot when polishing hard to reach places.. I used the same set-up as you until I wore through emery once or twice and decided to I needed find a softer shaft material.
Offline KASEY
Homemade Tools
« Reply #2 on: April 26, 2015, 02:34:37 PM »
I WENT TO BIG 5  and got a gun cleaning kit with brass brushes ,, they work fantastic
Offline StrokedAZ
Homemade Tools
« Reply #3 on: April 26, 2015, 03:31:14 PM »
^^^I agree.  The solvent and those brushes for cleaning guns works great on gaskets too.
Sent from my Galaxy S5
86 TRX 250R
