Author Topic: Keihin PWK Air Striker Float Level  (Read 3737 times)
« on: April 28, 2015, 12:29:20 PM »
I fired up the 350. Took her down the road for a little test ride. Going through the first couple of gears, down shifting no problem. Got her up into fourth, and she dies. Like I lost power or fuel. I checked the obvious, spark, fuel flow out of the petcock. Everything checks out. Removed and cleaned the carb. No signs of debris or any blocked orifices. So I check the float level, blowing in the fuel inlet, it shuts off at this position. Does this look a little low? And could this be my problem, with the bowl running out of fuel? I checked the gas cap vent and all the vent hoses, on the carb. Thanks guys.
« Reply #1 on: April 28, 2015, 12:59:28 PM »
float height should be 16mm or .630
« Reply #2 on: April 28, 2015, 02:46:27 PM »
Quote from: JesseA420;53803
From the bottom of the float, to the edge of the carb, where the bowl sits. Thanks Jesse.
