Author Topic: tmx 38 flat slide  (Read 3057 times)
Offline compton5
tmx 38 flat slide
« on: May 01, 2015, 06:58:09 PM »
im haveing some trouble jetting were is a good base to start with i have an 89 long rod on a esr330pv paul turner pipe tmx 38 cr ign k&n no lid on 105 32to1 mix ratio
Offline The_Steve_Man
tmx 38 flat slide
« Reply #1 on: May 04, 2015, 07:19:04 AM »
Which TMX is it?  There are 2 styles. The original tm and the tmx from a CR250?
Offline compton5
tmx 38 flat slide
« Reply #2 on: May 04, 2015, 09:33:05 AM »
tmx from a cr250r
tmx 38 flat slide
« Reply #3 on: May 04, 2015, 10:49:20 AM »
Is it lean or rich? I can tell you what my jetting is but it is on a ported stock cylinder. 32.5 pilot, stock needle on the 4th clip, s8 nozzle, and a 390 main.
I got the specs from Pro Circuit website on an 02 cr250. The 01 and 02 use he same needles but the 01 uses an s9 nozzle and the 02 uses an s8 nozzle. The nozzle or needle jet can richen or lean it without changing the taper of the needle.
The 03 uses different needles and I think a different size slide. Pro Circuit says to set the 03 up like the 02.
