Author Topic: I NEED HELP my 250r lost spark total restore everything new !!!!!  (Read 17726 times)
« Reply #15 on: May 04, 2015, 02:37:08 PM »
Quote from: team palmer 34;53998
ok  guy quit bashing my motor its all good its my coil thanks
hes not bashing m8, these are real facts. sounds crazy but true.
« Reply #16 on: May 04, 2015, 03:58:01 PM »
Quote from: team palmer 34;54002
yeah i think tested black and red wire out of motor got 19 ohms so sator is good i hold plug in hand and hold the head kick it ove no shock
red and black tested to ground or green should be 50 to 250 at 68 degrees according to honda
« Reply #17 on: May 04, 2015, 05:15:36 PM »
here ya go
« Reply #18 on: May 04, 2015, 05:44:54 PM »
and another,I dont think 19 is passing
« Reply #19 on: May 04, 2015, 07:15:40 PM »
yeah i had my ohms meter on the wrong setting i got a 194.7
« Reply #20 on: May 04, 2015, 08:48:18 PM »
Quote from: team palmer 34;54023
cool,your in perfect range
« Reply #21 on: May 04, 2015, 08:53:48 PM »
i got a oem coil coming so fingers crossed :wave:
« Reply #22 on: May 04, 2015, 09:21:33 PM »
Double check your flywheel key seems like someone had that issue and it caused some of those same issues.
« Reply #23 on: May 04, 2015, 10:57:21 PM »
Make sure the pick up is tightened down with locktite as well.
« Last Edit: May 05, 2015, 08:46:39 PM by broken1 »
« Reply #24 on: May 05, 2015, 12:49:33 AM »
Check all connections. Pull on them. Even the plug boot to wire. I've had it break off and didn't know it.
