Author Topic: Misc. parts:BMS-Walsh-PEP-Custom Axis-Axle  (Read 2507 times)
Offline CADWELL
« on: May 13, 2015, 06:47:38 PM »
Have some left over various parts from my last rebuild that I didn't need or use. Prices include shipping and please ask any questions you may have.
I'd prefer pay-pal and shipping will be done through UPS ground.
First up is an extended Axle that has outlasted it's finish. This axle is straight, but there is some very light surface rust and some gaulding or abrasion on the surface of the sprocket hub side. Indication of a previous blown bearing from previous owner of the bike. I was told it was an RPM, but the finish is to worn to see the RPM "DominiatorII" logo. The serial number has the letters "LS" so It may be an LSR. Axle slid right out upon removal  Asking $180 shipped.
Next up are some Walsh tie rods and heim ends. These came off of a YFZ so the pins are tapered. The rods themselves are 15" in length. With the ends there is about 18.5"  +/- of adjustment. The pins are snug and have no slop. $80
Next up is a BMS stem clamp, I have no bolts for it. SOLD
Next up is a BMS 1 1/8" handle bar clamp. SOLD
Next up is a dual rate rear PEP spring set-up. Main spring has the numbers: 0325.225.0800. Tender spring has: 0750.250.0275. Cross over ring also included. SOLD
Works Connection Clutch lever. The red ano is faded and the perch looks to have an ASV wheel on it. Still functions nice. Came off of a YFZ which is what the cable goes to. SOLD
Custom Axis remote resi's, front and a rear shock caps. These are left overs from a piggyback conversion I had done through Custom Axis. (SOLD)
« Last Edit: May 19, 2015, 08:23:32 PM by CADWELL »
« Reply #1 on: May 13, 2015, 08:15:12 PM »
Pm sent on shock resi's
Offline CADWELL
« Reply #2 on: May 14, 2015, 09:20:45 PM »
Shock resi's sold.
PEP springs pending.
