Author Topic: power valve removal  (Read 6358 times)
power valve removal
« on: May 18, 2015, 09:20:06 PM »
Besides the obvious of removing the 2 bolts how does the pv come off? I've smacked it with a dead blow and got it to twist, but it binds up the blade. Wth??
power valve removal
« Reply #1 on: May 18, 2015, 09:33:49 PM »
That seems odd. The rave on my pro x cylinder slides right out. Can you give the blade some "love" with with wood dowel from the inside? Maybe unscrew the bellows to see more.
power valve removal
« Reply #2 on: May 18, 2015, 09:42:38 PM »
Does the blade move freely when you push on it from the bottom?
power valve removal
« Reply #3 on: May 18, 2015, 09:46:20 PM »
Ya the blade moves freely when "centered".
Does it recess in it at all? All I know is it takes in oring to seal against the jug.
Offline 4WHLr
power valve removal
« Reply #4 on: May 18, 2015, 10:01:22 PM »
Iv'e never had my housing off, but have pulled the blade out by unscrewing the plastic top from the blade. The diaphragm seals to the plastic top , and to the housing. Thars as far as I have gone with it though. This is after removing the black plastic cover.
1986 TRX275R PC2000
power valve removal
« Reply #5 on: May 18, 2015, 10:08:47 PM »
Got it...there was a 3rd bolt...
I've neglected it...
Actually had to use a paint stir stick and the dead blow to get the blade out.
power valve removal
« Reply #6 on: May 18, 2015, 10:17:12 PM »
power valve removal
« Reply #7 on: May 18, 2015, 10:18:20 PM »
Not sure how you could get the blade out without taking off the base [MENTION=126]4WHLr[/MENTION]
Offline 4WHLr
power valve removal
« Reply #8 on: May 18, 2015, 10:18:38 PM »
Cool. Was the blade that dirty with carbon that it held it in ?
1986 TRX275R PC2000
Offline 4WHLr
power valve removal
« Reply #9 on: May 18, 2015, 10:22:23 PM »
Its been a while since I have seen mine:beaten:
By the pictures,
I see you are correct!
1986 TRX275R PC2000
power valve removal
« Reply #10 on: May 18, 2015, 10:28:31 PM »
Yup! That dirty/neglected :-(
power valve removal
« Reply #11 on: May 18, 2015, 10:47:59 PM »
I am late to the party but yes there is a 3rd bolt. Sorry Sam! At least you got it off without using a bfh! lol
power valve removal
« Reply #12 on: May 19, 2015, 06:46:10 AM »
Does that mean the blade wasnt actuating since it was stuck, or am i reading your wrong?
Never mind, just saw your reply to my question..
