Author Topic: cr250 pedal  (Read 6956 times)
Offline zcarlson12
cr250 pedal
« on: May 21, 2015, 10:03:17 PM »
My Laeger frame uses one but I have it all mounted up and it's hitting the propeg. Has anyone ran into this problem? Can you adjust the rear m/c shaft to make it longer? That might put the clevis lower raising the pedal if it can.
Offline zcarlson12
cr250 pedal
« Reply #1 on: May 22, 2015, 08:59:12 AM »
cr250 pedal
« Reply #2 on: May 22, 2015, 11:04:05 AM »
Wish I could help you on this one. My Laeger uses a TRX pedal
Offline zcarlson12
cr250 pedal
« Reply #3 on: May 22, 2015, 11:27:48 AM »
Thanks Tbone. My no-link also used a TRX pedal but this one uses a cr for some reason.
cr250 pedal
« Reply #4 on: May 22, 2015, 05:51:17 PM »
looks liek the way its hanging way down, the brake MC rod just needs to be way longer
Offline ryanowarrior
cr250 pedal
« Reply #5 on: May 22, 2015, 11:32:57 PM »
My Crf is the same way...ended up havin to file some off the pedal :( what rear MC are u using?
Laeger Crf
Laeger R
Walsh R
Walsh Crf (in the works)
Offline zcarlson12
cr250 pedal
« Reply #6 on: May 25, 2015, 11:01:58 AM »
I agree Jesse. I guess I'll be looking at doing what you did with the crf m/c. Ryano, I'm using the trx one right now.
cr250 pedal
« Reply #7 on: May 25, 2015, 01:06:13 PM »
You should have a little bit of adjustment at the clevis. I had a similar issue with alignment using a trx mc. I used a banshee clevis, which is a bit longer. You can find some different clevises on McMaster Carr's website also.
Good luck
-Jason
Offline zcarlson12
cr250 pedal
« Reply #8 on: May 26, 2015, 08:47:51 AM »
Thanks Jason I'll check out the Banshee clevis today at work. I do have a little bit of adjustment left at the clevis so I guess it will take some playing around with. Nothing like a custom build!
Offline TRX250RACER
cr250 pedal
« Reply #9 on: May 26, 2015, 06:35:58 PM »
A coupling nut and a short piece of threaded rod should do the trick.
cr250 pedal
« Reply #10 on: May 27, 2015, 01:30:55 AM »
The banshee clevis pin is slightly larger diameter than the trx.  I had to drill the hole on the pedal to make it work.
Good luck
-Jason
Offline zcarlson12
cr250 pedal
« Reply #11 on: June 03, 2015, 08:58:15 AM »
I ended up lowering the R clevis down a bit and did a little tweaking on the pedal. It's just about perfect but eventually I'll use a longer clevis. Thanks for everyone's help.
