Author Topic: Do I need a reed spacer?  (Read 8735 times)
Offline Steve
« on: May 31, 2015, 02:48:45 AM »
Would a reed spacer help? If so, how thick spacer & what reeds to run??
« Reply #1 on: May 31, 2015, 03:35:42 AM »
Quote from: Steve;54844
What engine are you working on?
What is done to the engine?
What pipe are you running?
Will a reed spacer help?.........
Help the engine produce more power?
Help the carb fit better?
Help remove some cash from your wallet?
Offline Steve
« Reply #2 on: May 31, 2015, 03:42:42 AM »
I bought it from a guy in Bakersfield who used it as a drag bike. It has a big bore kit.(almost 400 he said) high compression head, trx 5 pipe with a silencer. That's all I know unless take the motor apart.
« Reply #3 on: June 01, 2015, 03:09:04 AM »
Quote from: Steve;54847
Ok now we need answers to the last 3 questions:
Offline Steve
« Reply #4 on: June 01, 2015, 03:20:44 AM »
Make the engine have more power & top end.
« Reply #5 on: June 01, 2015, 03:25:24 AM »
Quote from: Steve;54889
Does it have a conventional reed block or a V force or ESR twin V type reed?
Offline Steve
« Reply #6 on: June 01, 2015, 03:27:59 AM »
Just a conventional reed box with no spacer.
« Reply #7 on: June 01, 2015, 03:33:58 AM »
A reed spacer will probably help the power a little.  The tip of the reed comes close enough on the big bore to the piston that the top petals of the reed cannot flow  well.
Offline Steve
« Reply #8 on: June 01, 2015, 03:38:28 AM »
Oh, ok.thax. The second bike I have has a 310 kit with a 3/4 spacer & boysen reeds. It's fast but can't beat the other one.
« Reply #9 on: June 01, 2015, 11:36:45 AM »
Who did you buy it from? Do you have a pic of the bike? Plenty of members here from the area. Someone will probably know the bike.
« Reply #10 on: June 02, 2015, 11:20:43 AM »
Quote from: Steve;54894
I do not think that putting a 3/4" reed spacer and Boysen reeds on your 400 is going to improve the power enough to smoke the 310 bike.  You have one or more components that are incompatible with the components that make up your 400 engine package.  The most common components that are miss-matched are the porting and exhaust system.
