Author Topic: '00 '01 cr alternator differences.  (Read 3735 times)
Offline dem3500
« on: June 04, 2015, 08:55:51 AM »
I've done a little searching on this and haven't come up with anything. Regarding the '00 '01 cr 125's and 250's what are the differences in the alternator assemblies? I know that the cdi's will swap between harnesses under any combination of parts but is there really a difference? The first part of the part numbers are the same. Even with the 500. I want to make sure I'm not messing with timing or anything else by running a 125 alternator with a 250 cdi.
« Reply #1 on: June 04, 2015, 11:39:57 AM »
Quote from: dem3500;54975
I would ask someone who has workred with ignition swaps. Dave http://trx250r.org/members/105-rsss396 has done alot with the ignition systems. Send him a PM to get good answers. Dave is a great guy to deal with.
Offline dem3500
« Reply #2 on: June 04, 2015, 12:07:19 PM »
Yea I've met Dave a few times. He's definitely a cool dude. I'll shoot him a pm. Thanks
Offline jimcarrier
« Reply #3 on: June 04, 2015, 03:03:17 PM »
i tried a cr 125 flywheel once. and wasnt working into the stator...    best is to check on ronnies for same number.
Offline dem3500
« Reply #4 on: June 17, 2015, 09:24:18 AM »
i talked to dave and he helped me out a lot but i decided to take it one step further and do a little more experimenting on my own. im also adding in the '02 cr250/ '03 cr125 to 2007 stuff as well. from my initial quick inspection there are actually parts throughout the years and ignition types there are actually compatible with each other across the board. i still have a long way to go but i will update as i figure things out. heres the pile i have so far. i still need to get a hold of a '02 + harness, voltage regulator, and cdi.
Offline FerrinMotorsports
« Reply #5 on: June 17, 2015, 03:17:59 PM »
I have an o2 ignition...Did you need to borrow it for your comparison?
Offline dem3500
« Reply #6 on: June 17, 2015, 03:30:23 PM »
Quote from: FerrinMotorsports;55259
i may take you up on that offer! thanks. i am not ready at the moment and i wouldnt want to ask you to borrow it and not get to testing on it for a month or two. i will let you know.
« Reply #7 on: June 17, 2015, 04:23:30 PM »
ok no problem...I'm not using it and have no plans except to maybe sell it in the future so no worries...
