Author Topic: QOTM Rules  (Read 16365 times)
QOTM Rules
« on: June 08, 2015, 02:44:38 PM »
  • One post per QOTM entry (i.e. no multi posts for the same entry).
  • You may post multiple entries (e.g. if you own 2 250R's, you may make 2 separate posts).
  • If you win, you may not resubmit that winning entry for the remainder of that calendar year.
  • No blatant advertising or promoting.
  • QOTM entries only (i.e. no commenting back and forth - this helps keep threads clean for voting purposes).
  • Fill out QOTM Entry Info Template here, or see duplicate template below.
Failing to comply with these rules may result in removal of QOTM submission.
Frame:
A Arms:
Swingarm:
Steering Stem:
Axle:
Carrier:
Locknut:
Hubs F|R:
Bars:
Brake/Clutch Lever:
Grips:
Foot Pegs:
Bumper:
Grab Bar:
Front Shocks:
Rear Shock:
Brake Lines:
Rotors F|R:
Rims F|R:
Tires F|R:
Body:
Plastic:
Graphics|Seat Cover:
Fuel Tank:
Engine|Drive System:
Cylinder|Head:
Bore & Stroke:
Displacement:
Carburetor:
Reeds:
Air Filter|Box:
Pipe|Silencer:
Clutch|Plates:
Gearing F|R:
CDI|Killswitch:
Cooling:
Other:
