Author Topic: 68mm piston kit for 88250r suggestions  (Read 2050 times)
Offline twistedwrench
« on: June 20, 2015, 11:08:40 PM »
I have a jug ported by esr has a 68 mm bore is this a good set up and any part numbers on 88 piston kit for 68mm piston any pros and cons would be appreciated
« Reply #1 on: June 22, 2015, 12:37:09 PM »
There should be a stamp on your piston indicating the type and size. I wouldn't alter the setup without the advice from an experienced builder. There are differences in pistons depending on rod length.
