Author Topic: Stator wiring bdt 330  (Read 9157 times)
« Reply #15 on: June 25, 2015, 02:03:10 PM »
good news glad you got everything figured out!
« Reply #16 on: June 25, 2015, 06:30:21 PM »
Quote from: Rupp250;55433
Like stated, you just need to trace the wire back.
Why do the wire look like a honey badger chewed on them for lunch?
Honey badger doesn't give a shit.
https://www.youtube.com/watch?v=4r7wHMg5Yjg
« Reply #17 on: June 25, 2015, 08:10:02 PM »
Good that you got it going. Instead of using those connectors. I like to use a male/female bullet set up, but put them on opposite wires so there will only be one way to connect later on. Oh and write down in a note book the way the wires go.
Offline Powerstroken
« Reply #18 on: June 26, 2015, 06:42:50 AM »
Yeah I was thinking of using those connectors and I should have just for the fact of if I have to switch out motors in the future and set my stock motor up with then I case it ever has to got back in. Just makes things a lot easier not having to cut and splice every time. I was just unsure if they were good to use in this application but then later realized that's basically the stock set up just in a square plug. I catch myself overthinking things at times but it's usually too late
