Author Topic: New intake  (Read 13601 times)
Offline christph
New intake
« Reply #15 on: July 27, 2015, 06:01:51 PM »
Any feedback yet on this setup, i.e., performance gains, installation pictures, etc?  I'm thinking about getting one.
1982 ATC 250R
1984 ATC 250R
1986 ATC 250R
1988 TRX 250R
New intake
« Reply #16 on: September 21, 2016, 09:52:20 AM »
Did you ever get this intake mounted up? If so, how did it fit? Can you share some pics with us?
Offline christph
New intake
« Reply #17 on: September 21, 2016, 05:35:57 PM »
I called Fuel Customs about this intake because I wanted to know if it was designed to fit the stock or aftermarket carb.  Most of us use a 38mm or 39mm aftermarket carb, which have a larger intake bell than the stock 34mm carb.  Anyway, he said he designed it for the stock carb.  He gave me the diameter--which I think was in the 50mm range--but it was smaller than my 62mm intake bell.  So, I don't think it will work with larger aftermarket carbs.
1982 ATC 250R
1984 ATC 250R
1986 ATC 250R
1988 TRX 250R
New intake
« Reply #18 on: September 22, 2016, 08:16:18 AM »
Quote from: christph;69673
Wow.....If that is the case, then the intake that they made is worthless. Almost no one uses the stock carb anymore. It's generally the 2nd thing to go, right after the factory exhaust pipe. Even when I ran a stock jug, I was running a 38 A/S. Well, that's disappointing. Thanks for the info [MENTION=284]christph[/MENTION] .
New intake
« Reply #19 on: September 22, 2016, 10:42:21 AM »
Since it uses a rubber collar to connect to the carb, I wonder if he could simply get a collar that tapers up to a larger carb bell?
Offline christph
New intake
« Reply #20 on: September 22, 2016, 02:09:10 PM »
Quote from: rablack21;69683
We talked about that on the phone.  He looked for a larger collar but couldn't find one.  I don't think you would want a smaller intake track flaring into a larger carb anyway, it might offer less performance than stock.
I don't want to discourage you guys from calling Fuel Customs and talking with Garrett about it.  Maybe he will make one with a larger intake.
1982 ATC 250R
1984 ATC 250R
1986 ATC 250R
1988 TRX 250R
New intake
« Reply #21 on: September 22, 2016, 02:23:58 PM »
Quote from: christph;69685
One issue I had with the led being larger was with aftermarket shocks the boot would rub and wear through so there's a fine line there.
New intake
« Reply #22 on: September 23, 2016, 12:52:17 PM »
Quote from: Skeans1;69686
Yeah, that's no bueno either.
Offline Sand_Blaster
New intake
« Reply #23 on: December 27, 2016, 03:06:55 AM »
Dang wish I would have read this again. I just got this kit as a gift from my bro. Did not know this works only with stock carb. Man the filter is huge
87 Trx250r & 99 Banshee
