Author Topic: Carrier question?  (Read 2596 times)
Offline Fire1
Carrier question?
« on: July 22, 2013, 08:14:29 PM »
Does anyone have a dual row bearing carrier with no bearing that you could measure how deep the bearing pocket should be machined on the brake cailper side. Here is a picture of a new RIS Designs carrier I bought from a member on another board. When it arrived it had dual row bearings installed and I immediately noticed the center pipe came up short and I thought the brake caliper side bearing was not pressed in far enough. On the brake caliper side with the bearing pressed in there's just enough room for the seal and doesn't have the normal space between the bearing and the seal for the brake hub to set in.
