Author Topic: NO-Link Intake  (Read 40427 times)
NO-Link Intake
« Reply #60 on: August 25, 2015, 02:58:04 PM »
Hmm my setup doesn't seem to be much longer than OEM, the hybrid motors must be quite a bit different
Offline troybilt
NO-Link Intake
« Reply #61 on: August 26, 2015, 08:17:37 AM »
Here you can see how long its going to have to be on a CRF LSR no link.  I did a rough quick scan of the frame to lay it out.
Elsinore 496cc Saber
NO-Link Intake
« Reply #62 on: August 26, 2015, 08:33:11 AM »
Troy that looks pretty similar to the Rolls no link Led intake I saw this weekend, that one was super long and narrow. What shock is the fattest shock body and spring setup available ?
Offline troybilt
NO-Link Intake
« Reply #63 on: August 26, 2015, 09:21:20 AM »
I always heard Elka had the largest shock springs/body.  I added some fudge factor into the shock diameters to ensure clearance.  From the side view you can see how far forward the carb is on the CRF vs. a 250r, I think I 250r will be somewhat shorter, maybe 4-5" shorter.  Definitely not the ideal setup for performance, but it will be better than what I've seen out there.  I also thought about mandrel bending some 3 or 3.5" tubing part way or something so the hole thing doesn't have to be coned.
Offline hontrx265r
NO-Link Intake
« Reply #64 on: August 26, 2015, 09:53:44 AM »
Something doesnt seem right. I have had a couple lsr hybrids and the intake did not seem nearly that long. Maybe yz vs crf or your full bump angle is over exaggerated?
Offline troybilt
NO-Link Intake
« Reply #65 on: August 26, 2015, 10:49:24 AM »
The compressed angle I wasn't sure.  the original intake/airbox he had hit the shock, so I tried to give him as much room as possible.
Offline hontrx265r
NO-Link Intake
« Reply #66 on: August 26, 2015, 12:08:03 PM »
This is an example of where every bit counts. The shock length, stroke, tire size, and brand of shock could all play a roll. I know you are doing what you can. Im simply saying how much of a pain this makes it to be a "fits all" a lot people dont understand that.
Offline lrd_250r
NO-Link Intake
« Reply #67 on: August 26, 2015, 02:43:03 PM »
troy your image looks like my lsr crf hybrid. the hose I am using is super long
Offline troybilt
NO-Link Intake
« Reply #68 on: August 26, 2015, 02:54:13 PM »
Mike, this intake would have to be pretty bike specific as you and other's have pointed out...
Offline troybilt
NO-Link Intake
« Reply #69 on: August 27, 2015, 08:12:32 AM »
Here is a mandrel bent 3" aluminum tubing down to 2.5" intake.  This will probably be the easiest for me to make, (i.e. cheapest)...  still need to work on the airbox for this one.
Offline hontrx265r
NO-Link Intake
« Reply #70 on: August 27, 2015, 10:31:01 AM »
This thing damn near needs a plennum near the carb..
Offline troybilt
NO-Link Intake
« Reply #71 on: August 27, 2015, 11:36:30 AM »
This is a classic example of what happens when a suspension guy doesn't talk to the motor guy when designing a chassis... LOL!
Offline ytman
NO-Link Intake
« Reply #72 on: August 28, 2015, 07:26:12 AM »
That Lone Star no link looks to be the worst case scenario as far as the airbox is concerned, with the raised upper shock mount and the lower pivot on top of the swingarm.
I can see from your bitchen work why LSR made that funky airbox the way they did.
NO-Link Intake
« Reply #73 on: August 28, 2015, 08:51:34 AM »
Quote from: ytman;57670
I agree. That shock angle looks nuts
Offline troybilt
NO-Link Intake
« Reply #74 on: August 28, 2015, 09:39:45 AM »
Can one of you give me a dimension for compressed shock angle?  roughly?  I took a guess so I might be farther back than I really need to be.  I do have the box designed now forgot to post a pic of the design.  Unfortunately I think this CRF no link will be a one-off deal, and I'll have to do a totally different design for other no links...  so we'll see if this design work is all for not.
