Author Topic: New ESR stator plates for 02-07 cr250  (Read 6222 times)
Offline derby
« on: July 22, 2013, 09:34:51 PM »
I know many have probably already seen this but I thought I would post it.  Can't wait to see what the timing curves look like.
http://www.eddie-sanders-racing.com/product_p/billet%20cr250%20ign%20adapter%202002.htm
Offline Wes350x
« Reply #1 on: July 22, 2013, 09:57:46 PM »
So you can use any 2002-2007 ignition now?
1988 250R
Offline christph
« Reply #2 on: July 22, 2013, 10:09:24 PM »
Ditto.  Does this mean the 02-07 ignition system can be used and is just as good (or better?) than the 01?
1982 ATC 250R
1984 ATC 250R
1986 ATC 250R
1988 TRX 250R
Offline derby
« Reply #3 on: July 22, 2013, 10:32:39 PM »
Yes, it sounds like the plate is designed to use the 02-07 cr250 ignitionn (since the 2001 cdi is d/c from honda).  Not sure where the timing will fall that will have to be determined to compare to the 01 setups.  I am going to pick one up in a couple of days and test it out.  I am sure eddie and tom have some good info since they designed the new plate.
« Reply #4 on: July 22, 2013, 11:31:15 PM »
Very curious on this!
« Reply #5 on: July 23, 2013, 12:13:26 AM »
That's awesome. Way to go ESR! way to keep up with changing times
Offline christph
« Reply #6 on: July 23, 2013, 03:12:37 PM »
Just called ESR about using the 2002-07 ignition system on the 250R.  They have the billet stator mounting plate (see website) and will be testing the entire system this week.  I was told the new system has a more complicated wiring harness and will cost $100 more than the previous setup.  So, instead of $599 it will be $699.
1982 ATC 250R
1984 ATC 250R
1986 ATC 250R
1988 TRX 250R
Offline troybilt
« Reply #7 on: July 23, 2013, 04:20:20 PM »
Hats off to Eddie and Tom for doing this.  Just as the CDI's were getting hard to find they come up with another solution.  Really anxious to see the timing curve comparisons.
Elsinore 496cc Saber
Offline 2strokesforever
« Reply #8 on: July 23, 2013, 05:43:45 PM »
Quote from: christph;5271
Did they say when the new complete system will be up for sale?
88 TRX250R
295cc L.A. Sleeve Big Bore Kit
Pro Circuit pipes, Pro Design head
Ohlins-Works Performance Suspension
IMS Pro Series controls
38mm Keihin Air Stryker Carb
200 watt Ricky Stator stator
Boyesen Rad Valve
KEEP THE DINOSAURS ALIVE!!
Offline christph
« Reply #9 on: July 23, 2013, 08:55:48 PM »
They said to call back next week, so it could be as early as a week from now.
1982 ATC 250R
1984 ATC 250R
1986 ATC 250R
1988 TRX 250R
« Reply #10 on: July 24, 2013, 08:33:33 AM »
I know the 02-07 run a capacitor/regulator in the system, so it will not be as tidy as he 00-01 but this is great that they are doing this.
« Reply #11 on: August 01, 2013, 07:58:30 PM »
anyone found out any info on the timing curves of these ignitions yet? or just how they stack up to the 2001 kits?
88 TRX250R
Boyesen Rad Valve
