Author Topic: FLP/CRF hybrid build  (Read 41706 times)
« Reply #30 on: January 18, 2016, 11:50:46 PM »
You probly need a big fcr for that motor
Offline 4Wheelmx
« Reply #31 on: January 19, 2016, 06:53:39 PM »
Quote from: 05450r;63404
I am going to buy a 07 CRF carb. They are 41mm.
Offline 4Wheelmx
« Reply #32 on: January 26, 2016, 10:17:51 PM »
Offline 4Wheelmx
« Reply #33 on: January 29, 2016, 08:13:30 PM »
Bad news. Turns out my 03 CRF450R engine does not fit this frame. If anyone one knows what engine fits in this frame I would greatly appreciate the info. Frame and sub frame will be for sale when I figure out what engine fits in it.
« Reply #34 on: January 29, 2016, 08:25:04 PM »
Is it a width problem with the lower mounts?
Offline 4Wheelmx
« Reply #35 on: January 29, 2016, 08:41:22 PM »
Quote from: 05450r;63829
Width and length. To narrow on the bottom motor mount and pivot bolt to lower mount to far apart, front mount to narrow also.
« Reply #36 on: January 29, 2016, 08:53:54 PM »
Hmm that's weird. Sounds like 02-03 have the narrowest mounts. Hopefully it's not set up for a 426
« Reply #37 on: January 29, 2016, 09:16:09 PM »
That sucks it don't fit. I would  have waited on the powder coat for the frame  just to fit the motor  first in case of modifications.  But it a very nice build  good luck. If you  were to sell the motor  pm me a price.  Thanks  rich
Offline 4Wheelmx
« Reply #38 on: January 29, 2016, 09:33:16 PM »
Quote from: thesmith87250r;63847
Thank you.
I didn't have the motor at the time I was building the roller. I just went with what the guy I got it from told me. Last time I do that.
« Last Edit: January 30, 2016, 10:51:31 AM by 4Wheelmx »
Offline 4Wheelmx
« Reply #39 on: January 30, 2016, 12:01:06 PM »
With the help from Flp, I think we got the chassis figured out. Turns out it uses a 88-89 swingarm, and doesn't use the pivot bolt through the engine. Uses a 03 CRF450R engine. I checked the serial number on my engine and talked to the guy I bought my engine from. Turns out he changed the cases with some 05 cases. There is hope that I can use this chassis after all. Here are some pics of my chassis back in the day.
« Reply #40 on: January 30, 2016, 12:14:32 PM »
Cool pics!! I'm glad you got it figured out, looks like I better find an 05'ish motor for the frame you motor came out of
Offline 4Wheelmx
« Reply #41 on: February 16, 2016, 07:28:18 PM »
Finally got the engine set in the chassis. I got the sprockets to line up. It is not bolted up tight yet. I couldn't find any bolts long enough for the front mounts and need to weld a piece in for the lower motor mount. I also got the 88-89 swingarm on. I need to do a little trimming on the back of the motor. It is rubbing the swingarm. I at least I am getting closer and know my engine will work in this chassis.
Offline 4Wheelmx
« Reply #42 on: February 17, 2016, 10:26:17 PM »
Engine is in and bolted up tight. Time to start bolting on all the rest of the parts. FINALLY!
Offline mandom250r
« Reply #43 on: February 17, 2016, 10:51:46 PM »
What kind of radiator is that? Looks huge
Offline 4Wheelmx
« Reply #44 on: February 18, 2016, 02:30:27 PM »
Quote from: mandom250r;64748
JRD radiator. Here it is next to my other aftermarket radiator.
« Last Edit: February 18, 2016, 02:39:02 PM by 4Wheelmx »
