Author Topic: kick starter blues  (Read 3502 times)
Offline Pj Uptmor
kick starter blues
« on: July 07, 2015, 01:24:14 AM »
Houston I have a problem. The kick starter assembly not engaging  everytime you kick start it. Only once in a while. It is a 88 engine and I haven't taken the cover off yet. Has anyone seen this problem before.
kick starter blues
« Reply #2 on: July 07, 2015, 12:09:50 PM »
Ryans theory was the spring was not pushing hard enough on the ratchet that it was not engaging. If your teeth are worn off or severely rounded the stronger spring will  not be a fix. You would need to purchase a new mechanism.
kick starter blues
« Reply #3 on: July 23, 2015, 12:44:33 AM »
[MENTION=482]Pj Uptmor[/MENTION]....what did you find?
kick starter blues
« Reply #4 on: July 23, 2015, 08:17:18 AM »
Quote from: Pumashine;55856
I agree with Tony. You have to check the teeth on the kick starter mechanism FIRST to make sure they aren't worn. If they are, that is your problem. In the case that I had with mine, teeth showed no sign of wear. So, after installing the strong spring, the slipping teeth problem went away.
Offline Pj Uptmor
kick starter blues
« Reply #5 on: July 24, 2015, 12:32:02 AM »
Sorry Guys been working 70 plus hours the last two week. I haven't got a chance to look into it.  Will keep you all posted when I get a chance to look into it.
